Refrigerators Logo
A
Anonymous Posted on Sep 04, 2014
WHATS THE TEMPERATURE FOR SHARP REFRIGERATOR SJ-68LM-C2W
Gil Shultz
Level 3:
  • Sharp Master 3,464 Answers
  • Posted on Dec 08, 2014
Gil Shultz
Sharp Master
Level 3:
Answers
3464
Questions
Helped
731174
Points
11104
Temperature for which part?
4 Related Answers
Anonymous
  • 859 Answers
  • Posted on Jun 02, 2008
SOURCE: I have a 4 door
From my search the only Sharp Regrigerators are sold in Australia and NZ. Here's the list of spare parts outlets:
State Spare Parts Wholesalers Contact Details Queensland Prime Electronics- Bowen Hills
24 Campbell Street
Bowen Hills QLD 4006 Phone: 07 3252 7466
Fax....: 07 3252 2862
Email: [email protected] New South Wales Prime Electronics- Flemington
185 Parramatta Road
Flemington NSW 2140 Phone: 02 9704 9000
Fax....: 02 9746 1197
Email: [email protected] South Australia Statewide Appliance Spares
178 Sturt Street
Adelaide SA 5000 Phone: 08 8231 3369
Fax....: 08 8212 3195
Email: [email protected] Victoria Speedy Spares
451 Macaulay Road
Kensington Vic 3031 G.B. Telespares
5 Hunt Crescent
Clarinda Vic 3169
Phone: 03 9376 1333
Fax....: 03 9376 7110
Email : [email protected] Phone: 03 9512 7604
Fax....: 03 9512 7534
Western Australia WA Appliance Parts
135 Russell St
Morley WA 6062 WA Appliance Parts
1/9 Blaikie St
Myaree WA 6154
Phone: 08 92754755
Fax:...: 08 9275 4935
Email :[email protected] Phone: 08 9330 1999
Fax:..: 08 9330 1677
Regards and hope this was Helpful,
Worldvet
Anonymous
  • 430 Answers
  • Posted on Jan 31, 2011
SOURCE: sharp SJ-F80SP-BK 4 Door refrigerator
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Anonymous
  • 43501 Answers
  • Posted on Jul 27, 2011
SOURCE: I have a sharp refrigerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
richroth
Richard Roth
  • 9472 Answers
  • Posted on Jul 31, 2011
SOURCE: I have a Sharp Frost
Normally when the refrigerator side freezes, it's because of an air flow problem. It can be caused from a stuck or defective air diffuser, a control board or sensor if this model has them or a thermostat, if it has one. You can check the temperature in the freezer section, to see if it's getting too cold (below zero). To check the temperature, place a thermometer between some packages. Air temperature is not a good check. If it is too cold, it can also cause the fridge section to get too cold. Usually, adjusting the control, to a slighlty warmer setting, will correct this.
2answers
I have a Sharp Fridge-Freezer, model SJ-F78SP-BK. The Fridge compartment freezes. If left on overnight, everything will freeze as if it had been left in the freezer. Freezer is working fine.
please increase the temperature in the fridge portion of your fridge as it sounds like you've set that compartments temperature too low.
Thank you.
How do I get the lamp cover off to replace the globe in my Sharp refrigerator? SJ-BB05DTXW1-EU
If your refrigerator has an incandescent bulb, you need to press in at the two hooks that secure the cover. See the picture here: https://www.manualslib.com/manual/1851908/Sharp-Sj-Bb05dtxw1-Eu.html?page=10#manual . Some models have LED lighting. For those models, the lamp is not user-replaceable.
I hope this helps.
1helpful
Sharp SJ F60PC SL refrigerator-freezer is freezing the refrigerator compartment.
I would take a look to make sure your coils are not frozen or covered with ice on the inside of the fridge on the back wall and also double check the drain line on the back.
You could have a faulty switch that controls the thermostat as well.
Not cooling and making ice
Ice is made when freezer temperature is cold. Freezer and refrigirator will not cool if iced up on back wall. Your defrost system failed, causing frost buildup on the coils and restricting airflow and heat transfer. Most likely cause is a defective defrost timer that is not advancing into defrost (2-3 times every 24 hours). Defrost system comprise Timer, Heater, and Thermostat. You need the tools to diagnose the cause or just try one by one to replace the parts. Other choice is to call a tech. The freezer must be defrosted one time manually to remove the long accumulated frost.
Sharp sj-19tgl refrigerator not cooling
Checked Thermostat and replaced.
I have a Sharp Frost Free refrigerator Model SJ-68LM-C2W. I have noticed that both sides of the refrigerator are very warm. Temp. is set at 4. The refrigerator is fully stocked and the problem is that...
We just started our new Sharp refrigerator (type: SJ-PT690R) yesterday evening after five hours of delivery. We set the temperature of the freezer & refrigerator at (-18 & 5) respectively. It is...
The fresh food compartment should be set to approx. 35 -37 degrees. Setting the fresh food compartment to a temperature below freezing does not compute and will not display an illogical reading. Adjust your settings according to your users manual and wait 24 hrs. before making any other adjustments
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Top Sharp Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
