SOURCE: Printer problem
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-56143-2&cc=us&lc=en&dlc=en&product=374568
Go to this page on the HP website and see try running this utility. Does that help?
SOURCE: my printer has jobs stuck
Sounds like one of the drivers in the printer program maybe goofed up.
Normal
0
Disconnect
the printer or at least be sure it is turned off. I'd do both and
reinstall the CD software program that came with the printer. When the
software program asks you to connect the printer to the USB port, do so and it
should again work properly.
Hope
this helps. Bud
SOURCE: Printer not printing documents in que
I have a Dell Photo 926 all in one fax, My print Docs are going in Que. What is the problem with the printer?
SOURCE: I have an hp 5510...Vista documents are in que not printing
Al tratar de accesar a Youtube se me env? a la siguiente leyenda Your browser sent a request that this server could not understand. Size of a request header field exceeds server limit. Cookie: VISITOR_INFO1_LIVE=DHKquoqA4NA; watched_video_id_list_BambinoCorleone=65f1d70558ca0a598d123ebeabdfc2b1WwMAAABzCwAAAGNGdVpvNFFsZ0Za saludos cordiales Guillermo
SOURCE: HP photosmart C5280 document stuck in print que
Delete document manually from the path mentioned below:
1) Press windows + R an then type spool
2) Go to PRINTERS folder.
3) Delete the files present in there.
If not able to delete then
1) Open command prompt.
2) type "net stop spooler" and then delete the files
3)Again type "net start spooler"
Your stuck document is now cleaned. You can start printing your document again.
