After the sprayer would not work Tuesday I put 2 gal of windshield fluid in last night still not working today
Sprayers are clogged up. You can clean out the sprayers with a needle, some have two holes so look carefully.
Try disconnecting the tubes from the spray head (under the hood). The press spray button, if nothing comes out, you have a bad pump. It liquid is pumped, then you need to clean or replace the spray heads - they are clogged or damaged
SOURCE: Rear windshield wiper sprayer
it might be in the motor pump or line is clog can you work the hose
SOURCE: 2004 Volvo C70 console light
IT IS A LITTLE BULB IN THE GEAR SELECTOR SAME AS ASTRAY LIGHT IT COSTS 10.00 AT A VOLVO DEALER AND THE REASON IT KEEPS BURNING OUT IS THAT BUMPS IN THE ROAD CAN SHOCK IT AND YES IT WILL BURN OUT
SOURCE: convertible roof does not work,mirror and rear
Check circuit breaker,37 in fuse box under bonnet
This is breaker for roof/heated window/mirrors
SOURCE: C70 Volvo 2001 convertible top stop midway when
One of the microswitches at the latches is not engaging stopping the cycle for safety reasons in case something is stuck, open the roof again and inspect the latch down areas for foreign objects or a misaligned microswitch.
SOURCE: How to check and add transmission fluid to a Volvo c70
The '01 C70 does have a tiny A/T dipstick, located under the large wiring bundle near the battery, under the radiator hose. It is very short, small and burried. Look very very carefully. I missed it until taking out the radiator hoses.
