Printcopy.infohttps://printcopy.info > code=SC401
Code: SC401 · Description: Transfer positive electrode current error A transfer roller current leak signal is detected. · Causes: • High voltage supply board set ...
Code: SC401 · Description: Transfer roller open error · Causes: • Transfer power pack defective • Poor connection between the transfer current terminal and the ...
I've never seen a message like that with the 0390H code. There is no mention of that code in either the user manual or service manual. The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that problem.
If the new PCU doesn't fix the problem, you might want to try calling Ricoh for support, since their documentation doesn't mention that code.
Hi it means that print head not going back to home position to complete it's process. Need to contact service center to repair and get the machine serviced on 1300 136 401 Australia wide.
Error Code 85System error code 85 means "The local device name is already in use." This error code may also display as "ERROR_ALREADY_ASSIGNED" or as the value 0x55.
