Why does yamaha rx-a1000 receiver keep turning off?
The receiver keeps shutting tv off, but comes back on within seconds. this happens regardless of how long the tv has been on. sometimes the tv is turned on and within seconds the received turns off. if can also be on for a while before it starts.
    Habit-Forming:
  • 166 Answers
How is unit connected to the tv ?
Posted on Sep 04, 2014
5 Suggested Answers
Anonymous
  • 236 Answers
SOURCE: yamaha receiver model rx-v550
it is your protection circuit working, preventing the unit from any further damage to circuitry. you can check first your speaker cabling for any short connections, possibly red/black terminal wires got entangled. if all ok then try removing all speakers then turn on the amp. if still does the same thing turning off then you have a problem with the amp output stage, shorted power output transistrs/driver probably. if the unit turns on normal without the speakers then you must have one or both of your speakers busted. by the way this amp is multi channel, after removing ALL the speakers connected, and does not turn off anymore, put the speakers back one by one and observe if the unit with turn off and on which set of speakers. otherwise if still trips even without the speakers, it is your amplifier that is deffeective, any of the five channels, main, rear,center. let me know result so i can guide you on how you can get it repaired and what will be the extent of damage in case.
reden
Posted on May 22, 2008
wizkid18
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
Anonymous
  • 236 Answers
SOURCE: ccr1cd keeps turning off
check your speakers cables, connections. check for possible cable short. If seem ok, remove all speakers, turn the unit on and see if still turning off. if it does then you have a trouble in your power amplifier, defective output sectiuon. could be your power and driver transistors. possible dirty or corroded system control board. try cleaning.
Posted on Feb 10, 2009
Marek Podmaka
  • 127 Answers
SOURCE: Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Posted on Mar 02, 2010
larry james
Larry Stiles
  • 301 Answers
SOURCE: Re: Yamaha RX V670 Receiver Powering Off
I have found there are capacitors failing through the output circuit. Look for 10, 33, 47, etc.. microfarads.In that range. I charge typicaly 150 to $200 with parts on something like this. Larry's Electronics [email protected]
Posted on Apr 24, 2010
Testimonial: "Good feedback!"
Maytag Model MMV1153AAW vent won't turn off; we have to unplug it and plug it in to use it so the vent won't run 24/7. When we plug it back in to use it, the vent comes on within 15 seconds and might shut...
Either your thermostat or relay to the blower has faulted. Thermostat is cheap but the relay is on the control board. So either replace the thermostat P#53001373 or replace the microwave as the control board is discontinued according to the information you provided. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jan 02, 2015 | Maytag Microwave Ovens
Tv keeps turning off
This is probably due to failing PSU capacitors. It is fixable.
May 19, 2014 | Televison & Video
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
TV won't come on
I have a 32 inch tv was working great then went into standby mode and wont turn back on. I have unplugged and am waiting please help!!!!
May 18, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
313 people viewed this question
Ekse
 Grubhead
Grubhead
