Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
A
Anonymous Posted on Sep 03, 2014
No 720p change output to 1080i
This message is displayed when using monlink input
1 Related Answer
snakehead
Henry Thomas
  • 1074 Answers
  • Posted on Jun 04, 2007
SOURCE: DVD UPSCAILER 1080i
get a new set of cable and try again if nothing then you will have to get a tech to check your set good luck.
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
2helpful
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3â„¢ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3â„¢ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3â„¢ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTVâ„¢ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
I have an r52wh74 tv. cant get it to display 720p
Hello Matiki64:
Yes this television does support 720p and 1080i. Hear is something that might solve your problem or at least get you going in the right direction.
Problems with DVI-HDTV Connection
• Make sure the DVI device is turned on and the cables are firmly connected. If problems still occur, turn off your device. Re-connect
your device. Reset the power by unplugging the power cord and plugging it back in.
• If you are tuned to the DVI-HDTV input and you’re receiving Unusable Signal message on-screen, contact the manufacturer of the
DVI device for further assistance.
• If you tune to the DVI-HDTV input and you see snow, the video goes in and out, or the video takes a long time to appear, your DVI
device is having trouble sending video information to the TV. Re-connect your device. Reset the power by unplugging the power
cord and plugging it back in. If problems persist, try connecting to the Y Pb Pr jacks instead if they are available or contact the
manufacturer of the DVI device for further assistance.
• If you have bars on each side of your picture, the device you connected might have a switch or a menu option allowing you to
change the picture format output that will fix this. Choose either 720p or 1080i.
2answers
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
*1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
1helpful
How to change from 480i to 1080i
The TV has a automatic scalier chip installed so it depends on the input signal that you are using. For example you are using a HDMI connection with a xbox 360 and you set the display setting to 720P then the TV will display it in 720P. If you set it to 480P then it will display it in 480P.
Playstation 3 not working with older model Pioneer AV receiver
If you have set the component output on the ps3 for high def,ie 720p or 1080i and do not get a picture it sounds like the component input is not high def enabled on your amp,change the setting on ps3 to standard 576 output,or put picture into tv then sound into amp if you want to run 720p or 1080i.
Hope this helps.
CABLE GUY.
I have the NS-PDP42 42" PLASMA 720-P and I would like to know how to change the screen resolution for hdmi devices. In the user guide it says to change it to 1280 x 720p but it does not tell how to...
There's no way to tell the HDMI input whether it should take 720p or 1080i input on this set. The best thing to do is experiment. Set your Comcast box to 720p and watch it that way for a while, then set it to 1080i and watch it for a while. The PDP42 has to do a little picture manipulation in either mode, but I think you'll find that the 720p mode will work best for you. I have this set with Verizon FiOS and I have the FiOS output set to 720p. Looks great, no complaints.
Ilo 42" plasma tv
Go the the settings on the cable box. look for output resolution, then change it to 1080i and 720p. now turn the box off and back on your tv will now display the input of wither 1080i or 720p depending on the hd channel your watching.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
