SOURCE: prince of persia the two thrones pc game
i cant remember that there is a hard part or level in prince of persia 2 thrones. but this will help you
http://www.gamefaqs.com/computer/doswin/file/926986/40399
read it and youll find on how to defeat the enemy on that arena
cheers
CHARCOIS
SOURCE: i am using nvidia gforce graphics card.......but
Hello :
Try this please :
Uninstall the game from your computer and reboot your system , then install it again and reboot system again . That could help fixing the problem.
You also can check system for viruses or malware . Try also check the registry for errors .
I hope this will help .
Please rate !
SOURCE: Prince of Persia is not
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
SOURCE: princes of persia Warrior within
Have you tried changing the properties of the shortcut to run in WinXP SP2 compatibility mode?
Right click the shortcut, goto properties/compatibility tab, choose "WinXP SP2 compatibility mode" in the dropdown box, then click apply.
This should solve your problem. If not, come back with a bit more detail, and it can go forward from there.
Hope that helps.
Cheers from NZ
