Question about Dometic RM2652 Refrigerator
CAN MY DOMETIC RV FRIDGE BE FIXED
THE FRIDGE WAS RAN OVERNIGHT WHILE UNLEVEL IT DOES NOT GET COLD NOW.it sounds like it trying to work but it does not get cold i can hear the hydrogen amonia running but fridge does not get cold can this be fixed
Posted by Cathy Daniels on
Lakeland Appliance Service
    Champion:
  • 323 Answers
Try unplugging it and allowing it to sit for 24 hours or so to allow the refrigerant and compressor oil to settles. then retry. If the filter got plugged you will need a refrigeration tech to repair it.
Posted on Sep 04, 2014
5 Related Answers
Anonymous
SOURCE: Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Posted on Jul 24, 2009
4stevetaylor
  • 62 Answers
SOURCE: Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
Posted on Jul 25, 2009
Anonymous
  • 9 Answers
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
VtToolMan
Mark
  • 704 Answers
SOURCE: Dometic rv fridge runs fine on elec, lights on gas
It is key that all control switches are in the correct position, depending on what power source you are using, gas, electric, etc. If the switches are not in the proper setting, the unit will not operate.
Here's the manual for your fridge that should be printed out for your use and reference (and reading enjoyment). It has all the info needed to operate and troubleshoot it.
Typically, when using any gas appliance with a pilot light, the sensor has to first be hot enough to trigger it to allow the safety gas shutoff to open and allow the gas to flow to the pilot/burner. Follow the instructions and you should be all set.
http://gasrefrigeration.net/dom_techdata/2707_2811SM.PDF
Hope you find this helpful and best regards!
Posted on Jul 30, 2009
motor1258
Mike Butler
  • 6674 Answers
SOURCE: my dometic fridge will not turn on
Check to see if you have a switch for storage, on, off etc. usually between doors, or near top right corner of fridge compartment. It may be in wrong position.
Posted on Jun 03, 2010
Dometic rv fridge does not get cold
needs to be replaced or try cleaning it out
Sep 04, 2014 | Dometic RM2652 Refrigerator
My 1987 dometic rm2600 works on electricity but not on gas. No light shows.
It is more then likely just a dirty orifice. The orifice is located just before the burner. It is a brass fitting that screws into the burner. It can be cleaned by removing it and soaking it in rubbing alcohol for a half hour then blowing it out. Do not poke anything through it! One cleaned try the fridge again, if this does not cure the problem then it is more then likely your thermostat that has failed. These thermostats are still available. They are a dometic dual stat and can more then likely be found on Ebay for around $100. For any other RV fridge issues please contact ArctiCold Refrigeration We keep it cold with locations accross North America we can help you with your RV fridge problems. ">
Aug 14, 2014 | Dometic Refrigerators
Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Oct 23, 2009 | Dometic RM2652 Refrigerator
Jul 06, 2009 | Dometic RM2620 Refrigerator
I have a Dometic RV fridge that wont get cold. It is a model RM 2401. It easily lights on gas, the coils get hot and it makes a little gurgling noise but does not get cold. Can this be recharged?
Jun 29, 2009 | Dometic RM2620 Refrigerator
May 18, 2009 | Dometic RM2620 Refrigerator
Will not stay cool
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jul 31, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
178 people viewed this question
Top Dometic Refrigerators Experts
Sheldon Dedek
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
