Question about Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset
Bluetooth headset how do i get it to work Problem - Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset...My phone cant find it, it was supplied with my new samsung phone..but no instructions on how to work it..!!!
Posted by davincicode on
  • 6 more comments
  • hkar Dec 10, 2007
    i have the same problem my phone cannot find the headset which i was given with my new phone
  • denward Dec 19, 2007
    My phone can find the headset,
     but i can't charge the headset. Instructions are not very clear or headset is faulty.
  • bigbenny123 Dec 20, 2007
    Same problem,headset is not pairing with my samsung phone,cannot find the headset.
  • wwe1 Dec 25, 2007
    my phone cant locate the bluetooth headset when i search for devices
  • Jax2034 Sep 03, 2008
    Same problem no instructions supplied
  • Anonymous Nov 07, 2008
    how do you put the decice in discoverable mode and what is the passcode?
  • Anonymous May 11, 2010
    Thanks really really helpful, i was getting really annoyed trying to figure out how to do this!
  • dkayinamura
    dkayinamura Nov 27, 2012
    I have the same problem with my phone LG 500p, the phone cannot find the headset HS-BT102-BK
Anonymous
THank you thank you.. you helped me solved my problem 0000 password
Posted on May 29, 2008
Anonymous
Yeah, it's a small problem. switch off the headset and switch it on back then hold down the power button. the blue light stays on(it has been reset) then search for it with your phone and pair with 0000.
Hope this helps
Posted on Jan 04, 2008
Anonymous
The reason is because the headset onlys pairs once
Posted on Jan 02, 2008
How to do ur music on bluetooth
First both your phone and your headset need to support Bluetooth A2DP profile. Mono headsets do not typically support A2DP nor, therefore, music streaming.
Apr 14, 2010 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
I m unable to pair my wep210 headset with my samsung omnia i900 mobile
the wep210 multifunction button needs to be pressed till blue light flashes then stops on blue light continuious this is when you ask your phone to find bluetooth devices it will pick it up
Jan 28, 2010 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
SAMSUNG MOBILE CANT LOCATE THIS HANDSET
I have bluetooth samsung 210 and I just bought it todaty , ,my mobile does nit see it
Jan 06, 2010 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
SAMSUNG BLUETOOTH WEP210 NEED TO KNOW HOW TO PAIR TO PHONE
Your manual can be found here... it should walk you through the connection process fairly easily.
Mar 23, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Lost my user manual. need to know how to turn bluetooth on to my
Last page of this manual for your headset... https://techtrain.samsungwireless.com/tekweb/Misc/Main/Accessories/WEP350_ss.pdf
Can't conect headset
you need to hold down the button on your headset until the blue stays on instead of flashing, then the headset has been reset, then try pairing your phone with your headset, and type in 0000 as the password, this should solve your problem :)
Sep 07, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Bluetooth code
Usually with headsets code 0000 works by default.
Aug 05, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset Logo
303 people viewed this question
Top Samsung Radio Communications Experts
Anthony Ward
Anthony Ward
Ekse
Jean Thiebaux
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
