If the memory says it is full when not, reformat the memory card. Take out the memory card and put it in a card reader. Hook it up with your computer. Go to My Computer. Look for the card reader. Right Click on it and click FORMAT. Formatting option is also available in the camera menu.
This is the instructions on how to remove existing ESS system in order for you to start on a fresh.
Please follow the instructions:
Uninstall Easy Share software:
Select Start > Settings > Control Panel > Add / Remove Programs. For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs.
Select Kodak Easy Share software.
Select Remove (or select Change, and then select Remove).
Run the Clear utility:
Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
Click the Download button, and then follow the on-screen prompts.
After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
Which size has the memory card? More than 1GB?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards. Why download firmware version 1.07? This firmware version improves memory card compatibility and provides general performance updates. KODAK EASYSHARE C330 Zoom Digital Camera Firmware
try doing a format with the camera. check your manual to see how to do this with your camera. Beware, formatting will erase anything on the card. i actually had the same problem with my camera, and this worked for me. Sometimes new flash cards are not compatible off the shelf--they need to be formatted. You should have at least flash cards to be sure card is not defective. Let me know if this helps!
