Question about Archos 605 WiFi Digital Media Player
How do i change battery in archos portable media player
How do i fit a new battery that i have
5 Related Answers
Anonymous
SOURCE: Archos 604 to Portable DVD player
All red/white/yellow audio/video cables are male at either end.
Posted on Oct 24, 2007
Anonymous
  • 145 Answers
SOURCE: I can't find music files
What format did you rip it to? Is it supported by the player. Try converting the files to mp3 then adding them.
Posted on Jan 29, 2008
Anonymous
SOURCE: Firmware upgrade results in arclibrary boot failure
I managed to overcome the problem by doing a factory reset. Unfortunately doing this initially created more problems in that on reboot the main screen appearance looked as it should but was almost inoperable. When the usb cable was connected to my pc the disc did appear on My Computer . The system folder was only 1MB. By good fortune I had copied and saved my Archos files before I carried out the factory reset. Copying the original system files ( about 20MB) back to my Archos returned normal behaviour. Further, two additional buttons appeared. One was a manual arclibrary update button and the other a USB setup button . I cannot get file transfer to operate under windows media player mode and Windows media player 11. No problem though. I use PC hard drive mode and carry out a manual arclibrary update. None of this was possible prior to the factory reset. I believe I would still be having serious problems had I not saved and restored my system files
Posted on Feb 11, 2008
Anonymous
  • 12 Answers
SOURCE: Archos 404 30GB Ultra Compact
call 0870 609 1693 this is the number for the archos uk repair team
Posted on Jul 20, 2008
Anonymous
  • 7 Answers
SOURCE: Archos 605 WiFi Digital Media
This is generally due to failed firmware updates, etc....here is something to try that has worked for some others:
1. connect the archos to the PC
2. click on repair
3. click on done and wait for a few seconds and you will see the archos as a drive in your windows (be patiant it takes some time)
4. once you see the drive, open it and make sure the System folder is empty, if not delete the file that exists there.
5. download firmware from archos website and put the firmware update file directly on the root of the archos drive
6. click repair again on the archos and done.
I've been told this does not always work on the first attempt, so give it a couple of tries if the first attempt fails.
Posted on Oct 19, 2008
1helpful
Can I change the battery on my archos 605
You can get a replacement battery here.
http://www.newmp3technology.com/605-battery.htm
By the looks of it, your need to open it up and unsolder the battery contacts and then resolder them.
If you don't feel up to doing it yourself, then try anywhere that repaires PC, laptop and such.
Check if they will do it and buy the battery yourself, might be cheeper that way.
Also check ebay incase it's cheeper there.
My Archos charges but doesn't switch on. I've tried everything I think the hard drive might be messed up. How much would it cost to repair my Archos 605 30gb Wifi.
You could contact Archos, but I gather their minimum cost for repair is $85. Plus shipping and parts.
A suitable hard drive would probably be around $100.
Amazon has a new Archos 7, 8gb wifi + 16GB microSD for around $200.
While the memory is smaller it is more rugged and better suited than a hard drive for a portable device.
3helpful
3answers
Bbc i player won't play on archos 5
that is because it it incompatible with the version of flash that is used by the archos. unless archos change that with a future update or iplayer suddenly becomes more backwards-compatible in the future then don't expect this to change.
How do i change battery in an archos 7
i have a archos 7 can you tell how I can change the battery
2helpful
How to change Archos XS202 battery?
Hi !
I found this site which sells batteries for archos xs202 :
http://www.newmp3technology.com/xs200+batteries.html
Then you have to remove the covers (back and front) of your archos. Then melt the tin that retains the battery cables with a soldering iron.
Then melt the tin again to fix the new battery cables to the motherboard and you're all set. I did it this very morning without problems.
1helpful
I can't find the model number on my Archos 605 wifi 160gb - can anyone tell me where it is?
serial number or model number - isn't archos 605 is the model number? serial numbers are usually written inside battery compartment or battery cover and rarely displayed via settings/information menu
1helpful
Transfer file to Archos 5 using usb port on DVR Station Dock
On your Archos 5 go into tools -> Files and you should have two Archos 5 tabs. Change one to your USB stick and the other to the Archos 5 and copy and paste. I have not tested this, but this should work.  Good Luck.
www.blogger.usarchos.com
Archos 404 camcorder
sound like you may need a new battery. look on the archos FAQ page to see if that is what it is. if so you can do this two ways you can fit the battery your self, you can buy the battery from newmp3technology.com or type archos.co.uk. or you can send it to the archos repair by calling 0870 609 1693 this will put you to the archos uk repair team
2answers
Archos 504 Powers Up and Immediately Shuts Down!
bad battery bad ones will show charged but cant push out full violts pc needs ok buy new one 1st
Archos 605 WiFi Digital Media Player Logo
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
Harrie
Ngoro
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
