How do i hook up external speakers/sound system. i don't see any audio outputs, but is there a way to add some?
If your sound system has an optical input, then use the TVs optical out socket and connect the two.
If the sound system just red & white phono/RCA sockets, or a 3.5mm jack then you need an optical to RCA convertor box. This will change digital into something that a conventional sound system can understand.
Here's the right type of box from Amazon
SOURCE: Philips 32TA2800
The Way Im understanding your problem is,
it seems like you need to hook your rcas directly to the tv and switch the surround to aux or something similar to that.
SOURCE: I have a philips tv
Most commonly people would use a splitter cable with one male prong and two female prongs at the other end. These are "phono" or "rca" type plugs and the cheapest place to get them is a hardware store. Hope you understand my explanation. Good luck, Russmann.
SOURCE: How do I connect external Bose speakers to Philips
can i connect more speakers to a cinemate bose
