Steelcraft generator 3300 watt Gas tank shut off valve left open with Gas in tank. Gas mix with oil in Crankcase
The floater of the carburator is bad(Needle). its leaking gas at the carburator and the gas is coming inside the engine at piston intake valves.
Replace carburator needle that stops the intake of gas at the Carburator.
Posted on Sep 03, 2014
SOURCE: water in oil
Natural gas and Propane engines do create moisture in the engine because these are cold gases. Therefore, when the engine is done running, the engine is hot and whatever gas is left will condensate and the moisture will drop to the bottom of the engine or oil pan. If this is using these gases then it is normal what you are seeing.
Posted on May 07, 2009
Sep 05, 2015 | Garden
Sep 02, 2014 | Motorcycles
Dec 24, 2013 | Briggs & Stratton Power Products 5,550...
Jun 20, 2013 | John Deere Garden
Jul 29, 2011 | Briggs Stratton H7159 & Stratton® 5500,...
May 21, 2011 | Sunpentown 2,800 Watt 6.5HP Power...
Feb 09, 2010 | Northstar Generator 9 Hp, 5500 Watt,...
Jan 31, 2010 | Watts Onan Portable Generator - 4000 ,...
Nov 30, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
Dec 19, 2008 | Briggs & Stratton Power Products 5,550...
381 people viewed this question
