Moisture inside Under viewer lens & screen
SOURCE: How To Remove The Fixed Lens From The Olympus E-10 For Cleaning
The easy fix is to buy a new camera. Or trade up to Canon equipment that is easier to clean.
-BLL63
SOURCE: olympus 795 sw lens moisture
Exterior:
• Wipe gently with a soft cloth. If the camera is very dirty, soak the cloth in mild soapy water and wring well.
Wipe the camera with the damp cloth and then dry it with a dry cloth. If you have used the camera at the beach, use a cloth soaked in clean water and wrung well.
• If any dirt, dust, sand, or other foreign material adheres to the periphery of the lens cover after use, or the lens cover does not move smoothly, wash the camera using the method described on P. 66.
Monitor:
Lens:
• Blow dust off the lens with a commercial blower, then wipe gently with a lens cleaner.
Battery/Charger:
• Wipe gently with a soft, dry cloth.
Note
• Do not use strong solvents such as benzene or alcohol, or chemically treated cloth.
• Mold may form on the lens surface if the lens is left dirty.
SOURCE: I was taking pictures in the rain and moisture
bring the camera bak to the shop explain the problem to them and they should be able to change the lens for you
SOURCE: camera lens broken
well i guess you can try any camera shop to have it sent out for repair, but get a quote first. Often it is cheaper to replace the camera rather than have it repaired. If you have insurance you can make a claim for the repair depending on replacement cost
Please rate our help to keep the service online
SOURCE: moisture on the lens
If moisture is in the lens, it is inside the camera.
Best to remove the battery or batteries and let it dry out in a warm area for a few days. This may not remove the moisture like taking the camera case off. This may be a job you may not want to tackle.
Corrosion will eventually cause problems within the camera.
It may be that the moisture inside may already have damaged some parts or components or caused a short.
