Question about Behringer EURORACK UB2442FX PRO Mixer
<!-- from fixya rte -->How do you set up for a simple pa system? - Behringer EURORACK UB2442FX PRO Mixer
Daniel Fitzpatrick
    New Friend:
    Problem Solver:
  • 4 Answers
It Depends how many Channels you are wanting for a basic 2 deck set up using Cdj's you would want 4 channel 2 per deck 1 master out and 1 booth so you can hear it through your head phones but if you were doing Karaoke you would want 6 channels for 2 microphones all going 2 the master out. but it changes again if us software and controller because most software has an internal and external mix mode. Here is a video that might help
Posted on Dec 10, 2014
  • Daniel Fitzpatrick Dec 10, 2014
I have a Peavey XR 8600 PA, I have tried adding an external vocal effects module into a mic line but it drops the output volume of the entire PA by about 75%. Any ideas why this is?
Well, I would say it isn't dropping the level of "the whole pa", it is just dropping the level of the input you have plugged the fx into. Check the settings on your fx unit, there are usually input, output and mix controls that are independant of "the pa" and affect the amplitude of the signal going into your mixer from the fx unit.
Nov 01, 2017 | Peavey Music
I am in a ukulele ensemble of 8. We all have electric pick ups in our ukes. what is the best way to connect to one amplifier, eg; using a mixer ?
It can plug into a guitar amp or PA system both. If you use an amp, you could hear yourself alone through that, then output jack "power amp out" to PA or put a mic in front of it from the PA. If you don't use an amp, it can plug into the PA but, you would only hear the 8 pieces together and have no way to hear yourself seperately.
Mar 29, 2014 | Music
How can I set this up as fold back monitor? I have two AC60 and PA system. I want to use the rolands as fold back and wondering the best way to do this. PA system - Yamaha 3MX 312SC with two 200 watt...
Connect a jack cable from the monitor out on the Yamaha to the AUX IN on one of the AC60s. Then connect a jack cable from the MAIN OUT of the AC60 to the second AC60. Set the level going to the foldback by turning up the monitor control for each channel going in to the Yamaha. Be sure to switch on in this order: YAMAHA>AC60(1)>AC60(2). Switch off in the reverse order. Start with all volume controls down and bring them up to the level you need.
Sep 08, 2011 | Roland Ac60 Acoustic Chorus Guitar...
I have the Harbinger HA120 Portable PA System set up in my room. I've had the system for about two years, and naturally have put some loud music through the speakers. However, now, when I send anything...
You need to do some test on the equipment. First check the resistance of each speaker. You may have a bad cable... and yes you can destroy the speakers with too loud a signal... HOWEVER if the system is made to work together this is USUALLY not a problem.
Aug 25, 2011 | Harbinger HA120 Portable PA System
What is the best setting EQ wise for a Sure beta 58A and a Sennheiser e835 mics? I have the HA120
Always start with flat setting. Be careful of boosting highs as feedback may be a problem Put the speakers forward so mics can't "hear" them.
Apr 06, 2011 | Harbinger HA120 Portable PA System
What do I need to hook up to our church pa system
Connection all depends on what type PA system you have. Here are the rules: Power this device from the SAME receptacle your mixer is powered by, even if it means running an extension cord. Use ONLY a balanced line from the mixer... either TRS cable or XLR cable.
Apr 02, 2011 | Samson Auro D412A Speaker PA Active
I have the Simmons SD7PK. It sounds as though the speakers to my amp or through our PA system are busted. What could be causing this?
First thing is to verify your sound system is OK by running program material such as a CD at normal levels through it. If it is OK then you need to consider if your drum set is overdriving your sound system. Drums generate high pulses and can easily saturate PA systems. First thing here is to connect headphones to your drum set and listen how the set sounds via headphones. If both these tests pass muster, then your PA system may be too small to handle the drum audio. In that case, get at least a 15 inch powered monitor, preferably bi-amped to run the drums through.
Mar 07, 2011 | Simmons SD7PK Electronic Drum Set
When we are trying to get a reasonable level of sound for vocals before it gets loud enough to be able to hear clearly with the band playing it starts to clip at the speakers now we are only using this set...
Proper level setting of the mixer is important. HOWEVER if the clipping is occuring at the speakers the only possible problem MIGHT be that you have a supersonic feedback that is saturating the speakers above your hearing range, Be sure you don't boost the highs too much with the EQ as this can cause the feedback that you can't hear. Also make sure that you power the speakers from the SAME receptacle as the mixer, even if it means running an extension cord to bring power to the mixer. This is to avoid a low frequency hum and common mode distortion/damage. A low frequency hum could cause the clipping.
It would be a good idea to get a sound meter to check the sound level. You should be able to reach 85 Db from this system without clipping. If you need more than that, you MAY need more speakers if the band instruments are too loud. Also if the band has amps that get into the vocal microphones that adds to the clipping level... make sure the mics don't "hear" the band instruments. Make sure your speakers are toward the audience from the mics to avoid the supersonic feedback problem. If the vocalists can't hear themselves with that configuration you need to set up seperate stage monitors.
There are some pretty good videos on YouTube about proper mixer level setup.
Jan 30, 2011 | Behringer Xenyx X2442USB / Harbinger...
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
My harbinger aps15 speaker sounds more with bass than with words to the music. how can this problem be resolved ?
Additional, if problem is isolalted to the speaker and it acts the same with a CD player, the speaker should be serviced. It may be the crossover network, or the horn driver has failed or a simple thing like a wire coming loose.
If the problem is in the laptop, check the settings for audio in the control panel as there are settings that could have got clobbered. Video games are notorious for clobbering settings.
Dec 20, 2010 | Behringer Xenyx X2442USB / Harbinger...
Behringer EURORACK UB2442FX PRO Mixer Logo
138 people viewed this question
Top Behringer Music Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Behringer Music Expert? Answer questions, earn points and help others
