Yoy can jump the truck off, but wile you are driving down the road and hit a bump the light and gauges on the dash start jumping around like it lost ground
It is probably a loose ground wire. If it only does it while hitting bump, then there is a loose wire somewhere. It may be loose fuse but probably loose wire or solder joint going to dash control board
Hey Alonzo,
One of three things,
1. Your suspension is WAY TOO STIFF!!! ..most likely
2. ALL of your shocks are frozen, which makes it seem like riding in a buckboard wagon
3. The suspension is way TOO soft.. (not likely)
Check the brake fluid. It may be just low enough to occasionally turn the light on as you hit bumps and it sloshes a little. Add a little brake fluid to the reservoir and check the brake pads all around.
One of my driving lights went out after hitting a bump on a dirt road, how do I replace the bulb? It's not the headlight, it's the driving light or fog light.
check shocks on back and sway bar for the engine wait until it dark and see if you have any sparks from wires and may need some new plugs i hope this will help you
