The keypad on the outside of the garage will not open the garage door. I have replaced the battery but still nothing.
U will have to re program the keypad follow the directions on the lid of the keypad now on some models u have to hold down * # at the same time until it stops blinking then enter your 4 digit code press enter hold for 2 sec if opener does not release and press again as soon as u hear the opener click or light blink press 0 to store code then wait 60sec and try
SOURCE: When we changed the access code on the garage door
Make sure you didn't accidently knock a wire off the rear of the motor unit. The wires connect to terminals 1 and 2 for the wall control.
SOURCE: (Chamberlain 1/2 hp Whisper Drive garage door
If the wall button will operate the door up but none of the devices do then look at the wall button. Find the lock button and push it for 2 seconds and then try the remotes again. This is your vacation lock. You can get a manual at chamberlain.com. Now if the door does not open or close with the remotes you can reprogram them. Press the colored learn button on the motor head and then press the button on the remote. Repeat for each remote. If they fail to program you will need a new logic board. Thanks BB
SOURCE: I have a Craftsman 1/2 HP garage door opener and
i beleive what has happend is the internal coding has been deleted this casn b the d-ram chip it remembers the entered code this can go then it forgets the codes then you cant use it generally
SOURCE: I have a sears 1/2 hp garage door opener, model
Make sure you are doing it properly. Press and hold the button on the opener 6 sec to erase it. Then hold the desired button 'on the remote' down, while holding the button on the remote down press and release the button on the opener. The opener should be synced up with the remote then.
