Question about Canon PIXMA iP4200 InkJet Photo Printer
Where can i buy an ipf 8000 Platen Fan in the UK
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: canon ipf 8000 print head problems
You need to boot the printer into service mode.
Hold down the roll/source button and the info button while you are powering on the machine.
This should get you booted into the service menu where you can then access the replace printhead function
When you have successfully replaced the printhead, reboot the printer to get out of service mode,
You may also want to check the firmware version of your printer and update it.
Updates can be found on the Canon website
Posted on Jan 27, 2009
Anonymous
  • 79 Answers
SOURCE: Canon iPF 8000: Hardware Error 03800500-2F2F and 03800500-2F30
it's a multiple problem....there is no enough ink for the head managment sensor to understand the good function of the print head.
Print a nozzle check to see what is going on
Then come back for more information
Posted on Mar 17, 2009
Anonymous
SOURCE: Canon ipf 8000 Error Code E161-403F
I have had two of my Canon plotters give this error.message, I had to manually move the carriage unit and replace the printhead. On one of the plotters the error message returned, on the second plotter I was able to go into service mode where it asked me to replace the printhead. I just went though the motions since the printhead was brand new and I was able to get the plotter to function correctly.
Posted on Jun 03, 2009
Anonymous
  • 79 Answers
SOURCE: i have a canon ipf 8000 showing a error
problem in the move of the carriage unit. Check visually if there is any paper inside the machine.
Check and come back later for more information
Posted on Apr 19, 2010
Anonymous
  • 79 Answers
SOURCE: ipf 8000 error code 003800500-2f-2f
there is no enough ink in the head managment sensor.
Go to menu, test print, nozzle check, check the grids 12 pair of grids.
Check if there are any brocken grids.
After that you have to perform head cleaning B twice or more.
If the problem still remains then replace print head.
also perform firmware update to the latest version though the official canon site
HOW CAN I RESET PRINT HEAD IPF 8000
https://groups.yahoo.com/neo/groups/Wide_Inkjet_Printers/conversations/topics/2373
Mar 10, 2015 | Canon imagePROGRAF iPF8000 Printer
Hello, i'd like to ask for advice. I have this one problem with canon ipf 8000, we've been using Schoeller H 64160 photopaper for poster printing with no problem. But recently we got different type of...
iI would check your paper type setting. you are working with a liquid type of ink and water will effect it. check the drying time of this ink. set your paper type to the set the type most suitable for this paper. try heavy gloss. you will find it under paper settings in the main menu. If no luck refer back to the ink and its compatibiliy with your ipf 8000. now if these are a recharged cartridges. you should change to the oem. meaning" original engineering manufacture".
Apr 09, 2017 | Canon imagePROGRAF iPF8000 Printer
Ipf 8000 error E161-403f
I think you need to manually move the carriage unit and replace the print head but go into the service mode first and see whether its asking to have the print head replaced before you spend any money.
Sep 30, 2010 | Canon imagePROGRAF iPF8000 Printer
I have a canon ipf 8000 showing a error 03130031-2F26 what is the error
Mar 31, 2010 | Canon imagePROGRAF iPF8000 Printer
Ipf 8000 error code 003800500-2f-2f
Feb 10, 2009 | Canon Office Equipment & Supplies
Canon ipf 8000 print head problems
Dec 22, 2008 | Canon imagePROGRAF iPF8000 Printer
Ink will not dry
Without having to apply a varnish, the best way is to use frog juice which is a spray which come as both matt or gloss and gives the same eefects as a varnish but isnt noticable with the matt. This reduces the solid black areas from smudging.
Nov 03, 2008 | Canon imagePROGRAF iPF8000 Printer
Canon ipf 8000
Try to update the firmware version to 1.32 (latest version on www.canon-europe.com).
Then check the move of the carriage unit if any foreign object is on the move.
Last try a lubricate the shaft and replace the shaft cleaner.
Oct 08, 2008 | Canon imagePROGRAF iPF8000 Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
74 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
