Question about Cub Cadet RZT L42 42" 22HP Zero Turn Mower - 17ARCACS010
How to turn off reverse stop mowing switches on a 2013 rzt 42 cub cadet
wadingriver
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,223 Answers
5 Related Answers
Anonymous
  • 146 Answers
SOURCE: I have a Cub Cadet RZT 50 mower. The left drive
First, check the level of the hydraulic fluid (usually the dipstick is right inside the fill cap, and you just raise the seat to access it). If it's low, fill 'er up with the right fluid.
If that's OK, test if the lack of 'pull' affects the left wheel in both forward and reverse -- try going up a hill forward, and backing up it in reverse. If it affects both directions, maybe you will be lucky -- the problem could be that the bypass for the left hydraulic motor has opened somehow. (The bypass is used to let you push the mower by hand in case of an engine failure, etc.) So look for a fat-headed bolt sticking out of the left hydraulic motor. Check that it's tight -- rotate it just like you would tighten a bolt, clockwise. If it wasn't tight, that may be the problem; just tighten it and try the mower.
If this doesn't resolve it, you probably have a problem in the hydraulic valves, hoses, or motor, and a trip to the dealer is needed. Probably won't be cheap, sorry my friend. Good luck, and please rate if this was helpful, thanks!
Posted on Jun 04, 2010
Anonymous
  • 200 Answers
SOURCE: cub cadet zero trn rzt 50 mower deck will not come on
try checking the cable running to it
Posted on Jul 20, 2010
Anonymous
  • 3 Answers
SOURCE: I have a cub cadet model 1420 with hydrostatic
i had exmark hydros i was told to never wash them, the water does more damage than good. have you checked or changed your hydostatic oil and filter latley? if you have, when doing that you have to be very careful not to get any foriegn objects in the oil resevoir, dirt, grass clipings, anything will ruin the hydro pump.
Posted on Sep 28, 2010
roadtech7
Matt Olenzek
  • 297 Answers
SOURCE: I have a 2006 Cub Cadet RZT 42 Zero Turn Mower
you have a wire that is grounding out, I would check the wire coming from the connector on the voltage regulator to the battery. This is the one in the middle position, look for a rub through and tape it up.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 03, 2010
Testimonial: "roadtech7 was SUPER helpful and very patient. A very knowledgeable tech. Thank for all the help pardoner! "
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: I have a cub cadet RZT 50 mower deck and my
The problem is the clutch it's self... it is slipping and when it gets too hot it just quits...
The clutch will need to be replaced and that often is not a fun job. You also should have specialty tools to do the job, as they are very hard to get off the shaft many times... the same heat that stops the clutch, almost welds it too the shaft...using heat to free it therefore does not work like it normally would.
Just for giggles a grins, check for power to the clutch after is stops...I think you will find that it is still getting power to it, it just is not engaging or staying engaged anymore...
heatman101
Posted on Jul 14, 2011
How can I determine which safety feature is not allowing me to start my cub cadet rzt 42 lawnmower?
You first need to find out why this safety feature is being triggered rather than bypassing it for your safety.
Jun 07, 2016 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
My RZT 50 turns blades on when levers are pulled back instead of shutting of and shuts off when in forward position ? could it be a switch is bad if yes what switch?
Sounds like someone has been working on the wiring, probably trying to bypass the reverse cut out switches . If you follow your steer control lever down under the plastic console covers there will be a switch, one on each steer lever by where it hinges. I don't think the switch is bad because it would not work at all if it was.It is like a door bell switch, when you pull back on the steer control lever it pushes it in and disconects the circuit to the PTO switch and the blades quit until you push them forwards and lets the curent through again. Also check the push pull PTO switch .Every safety switch on the tractor will meet at that switch and plug into it, . That model cub RZT50 has to have the worst switches ever made, but they are available and cheap on ebay. Plunger Switch 430362 430 362 for Cub Cadet Troy Bilt MTD 700 Series 725... PTO Switch MTD Cub Cadet Mowers GT RZT LT Force Mowers 925 04175
Apr 25, 2016 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
How to turn off reverse stop mowing switches on a 2013 rzt 42 cub cadet ?
unhooking your battery will clear codes might work for this to as long as your tractor isint in reverse
Sep 02, 2014 | Cub Cadet Garden
The mower deck on our Cub Cadet RZT 50 mower stopped working while mowing. We have cycled the PTO switch several times with no change. The belt is in place and the mower blades rotate freely by hand. The...
You can check the clutch by taking a wire from the ground and a wire from the positive side of the battery and energizing the clutch directly with the belt off to see if thats it. It could simply be a wire loose in the connection on the clutch....their soldered on.
May 30, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cub Cadet RZT L42 42" 22HP Zero Turn Mower - 17ARCACS010 Logo
673 people viewed this question
Top Cub Cadet Garden Experts
dannydoesita
Marvin
Marvin
Dennis Key
Dennis Key
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
