Cooktops Logo
A
Anonymous Posted on Sep 02, 2014
Why do Jenn-Air cooktop igniters click when the exhaust fan is on med-high and the burners are on low flame setting ? ?
Jay Plesset
Level 3:
  • Master 2,942 Answers
  • Posted on Sep 02, 2014
Jay Plesset
Master
Level 3:
Answers
2942
Questions
Helped
668443
Points
9879
Igniters sense flame temperature, and if the fan cools the temp sensor down, your cooktop thinks the flame has gone out, so it clicks to reignite it.
5 Related Answers
Anonymous
  • 213 Answers
  • Posted on Nov 30, 2007
SOURCE: Thermador Gas Cooktop Won't Stop Clicking : SGC304RS
theres a part in the cooktop called a spark modual. replace it. when i goes bad the problem your having is what it causes
Anonymous
  • Posted on Mar 29, 2008
SOURCE: Jenn-Air JGD8130 Gas Cooktop will not ignite
I just ordered one of these---sounds like people are not happy with this model---please get me more info
Anonymous
  • 150 Answers
  • Posted on Apr 23, 2008
SOURCE: igniters are not working right
when you turn any burner control to lite all ignitors should click this is normal industry wide. the ignitors are controlled by switches that are placed over the valve shafts they are wired up together so thats why they all click when you only operate one valve don't worry about it. the ignitor stays on untill you back the valve off a tad this is also normal.
Anonymous
  • Posted on Aug 18, 2008
SOURCE: Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
robert
  • Posted on Apr 16, 2010
SOURCE: exhaust fan comes on when burner turned on
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Flame flares up sporadically while cooking
Due this test, turn on all burners on high, as you turn them on, does the problem burner change in volume or size of flame? If all burners are on and you only have issues with that single burner you need to replace that burner valve only. If you have issues with all burners when the all are on, replace the regulator.
I hope this helps and leads you in the right direction.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Hello. When I turn on a burner, another one
they will all click when lighting,
if this is happening after ignition, turn your flame just a bit higher, your loosing flame ground
Jenn-Air 36 Gas Cooktop
try to use macth in the burner u said,if ok the flame,the problem is the igniter wire,nid to replace,but if u use the macth then the flame is malfunction again i think the sensor is the problem,nid the tecnician coz is hard to repair,sometime after repair the sensor it problem again in next day
tnx gerbee
Flames too high Jenn-air CCG2423
Definitely cut your loses and get a cooktop with a warranty. That unit sat on the back shelf for a reason.......it didn't work properly.
Also, but a cook top that is compatible with the safety knobs they sell as child guards at places like lowes and home depot.
here is a link to show you how the child proof knobs work
http://www.associatedcontent.com/article/327577/childproof_your_stove_safety_1st_stove.html
2answers
Jenn-Air Gas stovetop
try to clean the burner and then try it.
Creda 4 burner, converted to LP
Your flame is perfect if it's just the very tip that is yellow or white. All burners should be adjusted this way, on highest flame.
4helpful
2answers
Exhaust fan comes on when burner turned on
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
