A
Anonymous Posted on Sep 01, 2014
What is the density
5ml sample has a mass of 5g
k24674
Level 3:
  • Office Equip... Master 8,093 Answers
  • Posted on Sep 02, 2014
k24674
Level 3:
Answers
8093
Questions
0
Helped
4671772
Points
21595
Density =mass/volume =5g/5 ml= 5g/5cm^3=1 g/cm^3
Sharp MX m 265 n F2 40 error'
Toner density sensor trouble
Causes
Toner density sensor output abnormality (Sample level 25 or less, or 201 or above) Connection trouble of the connector and the harness. Developing unit trouble. PCU PWB trouble.
Remedy
Replace the toner density sensor. Check connection of the connector and the harness. Replace the developing unit. Replace the PCU PWB.
If it says 1 teaspoon of wormer =5ml then how many cc per pound
what you are really asking crosses over from measurement of volume to dosage per weight and there is no method to do that
the direction for dosing will say how many ml to use per pound of animal
so if it is 5ml per pound of animal , weigh the animal and multiply that by the 5ml and you will get your answer
Is diameter is 3000km and the mass is 16 times the mass of the sun, what is the density of the disk
Density is mass divided by volume.
Mass of the Sun is 1.989E30 kg, in exponential notation, where we have to move the decimal, in this case, 30 places to the right.
16 times the mass of the sun is 31.824E30 kg or 3.1824E31 kg.
Volume of the disk is 4/3 pi r ^ 3, where ^ means raised to the power of.
First, we have to take the diameter of 3000km and divide by 2 to get a radius of 1,500km. I get a volume of 14137166941.15 or 1.4137E10 km^3.
Now, dividing the mass by the volume, we get the density.
Good luck.
Paul
How to calculate density
density is defined as the ratio of the mass of a substance to the volume occupied by that substance.
To represent density one use the Greek letter RHO (looks like a rounded p)
RHO= mass/volume
Unit of density is gram/ cm^3 or kg/m^3
Relative density is the ratio of the density of a substance to the density of pure water (at about 4 degrees Celsius). In this relation both densities must be expressed in the same units.
Have a 50 ml bottle how many 5 gram containers can I get
That depends on what's in the bottle. If you have 50ml of water, that will mass 50g so you can get ten 5g containers. If you have 50ml of mercury, that will mass about 677g so you can get 135 5g containers.
1helpful
1600 cubic feet equal how many pounds.
A cubic foot is a unit of volume. A pound can be a unit od mass (weight) or a currency. Either way a volume cannot be converted into a mass nor a currency.
If you are doing homework read carefully the question to figure out what substance they are talking about.
Once you know the substance look up its density or specific gravity and do the calculation
mass (in pouunds) =density (in pounds per cubic foot) * volume (in cubic feet)
As you see, if you know the density (specific gravity) in pounds per cubic foot, you can calculate the mass of any volume of that substance (in cubic feet).
And please, never try to convert a volume into a mass.
How to convert mass(kg) of fuel product to Litres
To convert mass to volume(which litres is a unit for), you'll need the fuel's density. The units for the quantity is mass/volume, often kg/m³ or similar. To get the volume, divide the mass by the density: kg/(kg/m³)=m³. Since 1000 litres is equivalent to 1 m³, you'll need to multiply by a thousand to get the answer in litres.
1helpful
A block of stone has a mass of 405 kg and a volume of 0.15 m3. Calculate its density.
The density is the mass divided by the volume. Divide 405 by 0.15 to get the density in kg/cubic-meter.
My phaser 740 has print that flakes off when you print pictures with real dark areas. I assume it needs more fuser heat or less paper speed. The problem is I can' t figure out how to adjust either of these...
Recalibrate the colors. Flaking is sometimes caused by more ink/toner than can be fused to the media. There's a limit for the total amount of ink/toner. Yours may be set too high.
You'll need a copy of the Printer's User's Guide (also Downloadable from Xerox.com)
Controlling Color Density
When colors look faded, adjust the toner color density to extend the life of the components.
Print and use the Color Reference Page 1 In the printer's front panel, scroll to Calibrate Colors,
press Menu and print the Color Reference Page. 2 Compare the Color Reference Page to the Color Density
Samples on page 39. Make a note of the value (-10 to +10) for each color that most closely matches the samples.
3 Adjust the density for each color: Enter the value noted in Step 2 in the Calibrate Colors menu, under Adjust Each Color.
? Decrease color density: Press . ? Increase color density: Press --->.
4 Reprint the Color Reference Page; check your adjustments
How many atoms are present?
(0.540 g)(6.02 1023 atoms) 27.0 g 1.20 1022 atoms
Because density equals mass per unit volume, the mass of the cube is m V (2.70 g/cm3)(0.200 cm3) 0.540 g write this relationship twice, once for the actual sample of aluminum in the problem and once for a 27.0-g sample, and then we divide the first equation by the second: m sample m 27.0 g kN sample kN27.0 g
m sample m 27.0 g
Nsample N27.0 g
To solve this problem, we will set up a ratio based on the fact that the mass of a sample of material is proportional to the number of atoms contained in the sample. This technique of solving by ratios is very powerful and should be studied and understood so that it can be applied in future problem solving. Let us express our proportionality as m kN, where m is the mass of the sample, N is the number of atoms in the sample, and k is an unknown proportionality constant. We
Notice that the unknown proportionality constant k cancels, so we do not need to know its value. We now substitute the values: 0.540 g 27.0 g Nsample 6.02 N sample 1023 atoms
k24674
ADMIN Andrew
ADMIN Andrew
