Question about Mag Innovision LT782S 17" Flat Panel LCD Monitor
How to open lt782s model 700?
Black screen
1 Related Answer
Stephen Lam
  • 670 Answers
SOURCE: Mag monitor lt782s - green light on screen black
This means that the power supply board has a problem. The problem is that the part of the circuit that controls the backlight has failed. This is usually caused by capacitors that have gone bad or transistors that have shorted.
Posted on Dec 23, 2010
Dec 23, 2010 | Mag Innovision LT782S 17" Flat Panel LCD...
Need drivers for my LT782s
Try this link - http://www.driverstart.com/start725240.html
Here you may find all Mag Innovision drivers for your device. Below you may find useful LT782S links for drivers and software. Driver is a small useful utility what helps your LT782S hardware works fine.
Sep 26, 2010 | Mag Innovision LT782S 17" Flat Panel LCD...
Screen blacks out, but power light stays green. I can repress the power button and it will come on for a short while
Power supply, replace the caps, 220uf,470uf,680uf. you will see the tops of them are popped out, check the board too see if its turning color from the surface mount transistors that drive the lamps..If its turn an very dark color the parts have been very stressed out..
Feb 22, 2010 | Mag Innovision LT782S 17" Flat Panel LCD...
Screen goes black after a few seconds.
when the screen goes black shine a flashlight on it. If you see a dim image the back light needs to be replaced. Otherwise check the inverter as that may be causing the problem as well.
Sep 07, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Black screen monitor
souns like the dc-dc convertor board that supplies the backlight gone faulty possible poor soldering on board
Oct 07, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Screen had multi-color vertical lines, then went black
the monitor has power board issues it is not your video card. its not dead but it will require some soldering work to repair.
May 22, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Mag lcd monitor
probably capacytor problem in the mainboard, take it to the lab it will be cheaper then buying new one
May 06, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Power adaptor
you can find one at zp-electronics. it's an is-034 cord.
Mar 30, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Compaq presario 700 Black screen
There might be several reasons, hardware nor software/operating system, but most probably from the hardware. Can be the graphic card (if you can notice the hard disk work well - from the sound), can be the hard disk, or even the mother board. We have to go through the symptom.
Since it is still new, the best solution is back to the seller for guarantee.
Feb 27, 2008 | Compaq Presario 700 470024-192 Notebook
I think it's busted
you need to open the case and check the capacitors and if they seem doomed or color is leaking then replace the bad ones that should stabilize the power to the vertical ic chip
Nov 20, 2007 | Mag Innovision LT782S 17" Flat Panel LCD...
Mag Innovision LT782S 17" Flat Panel LCD Monitor Logo
49 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
ThaMp3Doctor
ThaMp3Doctor
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
