To update bios on your laptop, you laptop must be booting to windows, you should be able to use it.
Click on the below link, this will direct you to the dell support site.
http://www.dell.com/support/home/us/en/04/product-support/product/inspiron-1545/drivers
Once you click on this link, choose the operating system you are using and scroll down to find the BIOS, click on the drop down and click on download. Save the file to your desktop and once it is downloaded, click twice on it and it will start the installation.
Ensure that the battery is charged more than 10% and the ac adapter is connected.
It is always recommended to updated bios only if you feel there is any issue with it.
SOURCE: Dell inspiron 1545 laptop and the same webcam problem.
open your my computer, click on "c" the system will tell you the information is hidden, click on the link and open up the operating system and look in the drivers or there in C and se if you can find you web cam driver, when you find it you might have to force the opening of the driver to install, and once you do that plug your web cam in and see if the system see's it and installs the drivers for the cam, if you installed the driver origanally witht he web cam installed you will have to remove the web cam and unistall the driver and re install it and then plug the web cam back in, and that should help correct the problem.
SOURCE: dell inspiron 1545 start up problem
try press F12 when you see the DELL Logo, if it still goes to BIOS you need to replace keyboard
SOURCE: dell inspiron 1545 power on administrator password pro
You can get a Password Reset disc download and burn to CD. Copy/paste the address below, into your address bar of your browser.
http://pogostick.net/~pnh/ntpasswd/cd080802.zip
Download this file and burn it to CD. Put into drive and turn on PC, and boot from the CD. Follow instructions, choose the correct USER. & BLANK the password. make sure you say OK to write the data, and reboot. The logon password will now be reset blank.
SOURCE: blank screen on my Dell Inspiron 1545
if your getting your dell logo it means your disply is working fine
may be u r windows is not working properly just try to up-date your windows with any windows disk
SOURCE: laptop dell inspiron 1545 no power up
Hello anourkhader
When was the last time you used it, and were there any problems? To find the solution to this problem is a matter of elimination. You should check the following:
Step 1 - Power
- Try an alternative power adapter
- Try plugging in your laptop to an alternative power supply
WARNING - BEFORE PROCEEDING, PLEASE FOLLOW THE FOLLOWING SAFETY PRECAUTIONS!
1. REMOVE THE POWER ADAPTER FROM YOUR LAPTOP
2. REMOVE ALL PERIPHERALS
3. WEAR A WRIST-GROUNDING STRAP, AND CONNECT IT TO AN UNPAINTED, METAL SURFACE. IF ONE IS NOT AVAILABLE, TOUCH AN UNPAINTED METAL SURFACE TO DISCHARGE ANY STATIC FROM YOUR BODY
Step 2 - Remove and reset basic hardware items
Remove and reseat the items mentioned below in the order they're mentioned:
- AC adapter
- Battery
- Memory
- Hard drive
For instructions on how to do this, please refer to your user manual. If you no longer have it, you can download it from here: http://support.dell.com/support/edocs/systems/ins1545/
If after following the above instructions, your laptop still doesn't turn on, I would recommend that you contact Dell customer support, which you can do by following this link: http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_technical_support?
I hope this helps. Please feel free to contact me if you require further assistance.
ajblaj
