Temperature doesn,t get above 10degrees
SOURCE: Not cold enough
Should be a thermostat with a black knob in the freezer. Usually they are marked 1-7 1 being the warmest and 7 the coldest. Usually clock wise + colder. Adjust by only 1 number per day. See how it responded the nest day. The set point is designated by a notch or arrow on the cover plate. ;)
SOURCE: Freezer is not cold enough
You need to check first that there is no leakage of your gas in your compressor system thats responsible for cooling the refrigerator. If you have the manual you an read it to locate the regulator
SOURCE: freezer not cold enough
the dryer is already sock ,, you need to change it and refill the gas
SOURCE: Freezer not cold enough and fan doesn't blow.
if door was left open for extended period of time it has probably iced up around the evaporator fan, try to defrost around fan area using a hair dryer
