Question about Frigidaire Gallery GLWS1339EC Top Load Washer
Frigidaire washer repairs
Make poping sound then smoking now wont wash spin or drain
mitzie
    New Friend:
  • 40 Answers
It almost has to be the belt think the front comes off to check it out
Posted on Sep 08, 2014
5 Related Answers
docjohn174
john gagnon
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
Anonymous
  • 196 Answers
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Nov 12, 2008
Anonymous
SOURCE: washer does not spin after wash cycle
Problem solved. It was one of the resolutions posted by one of your clients. TKS. PS this one of the best problem solving sites that I have seen. Great Job Rick
Posted on Jan 31, 2009
Anonymous
  • 8619 Answers
SOURCE: Frigidaire FWS833AS1 - My washing machine recently
Hi
Thanks for using FixYa. The smell might be due to burning of lid switch. If the washer isn't spinning then it might be dueto a Lid switch or due to a bad motor coupler. You can check for the lid switch& replace it--
First unplug the washing machine. Then remove the two screws that hold the top consolein place; these are located in back of the main console (where the dials are).Once removed, the entire console swivels back, exposing the wiresunderneath.
After this unplug the wiring harness that is connected to the washing machinetop flat surface. Now remove the two s-shaped brackets with a screwdriver byprying underneath. This will allow you to remove the main sheet metal framearound the washing machine. The lid switch assembly is located under the topconsole. Now, remove it and replace with the new assembly and put it backtogether.
Please look this schematicfor lid switch location(part # 50)--
You can buy the lid switch from this link--
Frigidaire FWS833AS1 Lid switch/assembly
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Oct 16, 2009
Anonymous
SOURCE: frigidaire washer model #fwt425rhso
This is the second time I have had to replace the drum/support shaft on this washer. Not only is it expensive, but very difficult to replace. Probably the very worst washer on the market for this reason. And I only do 3-4 light loads of laundry per week. A definate design flaw on the part of the manufacturer.
Posted on Oct 20, 2009
1helpful
Frigidaire gallery washer smoking and not spinning
Sounds like you either have something in the pump or maybe the belt is slipping on the pulley.
Frigidaire gallery top load washer is leaking and will not wash big load
Hello msmm50 - Contact a professional so they can properly and accurately diagnose the unit for repairs. Sounds like you have a leak in the drain lines or the water valve.
Smoke out of washing machine
A Model# would help us Folks at FIXYA with the possibilities. Thanks
My frigidaire washer model # fws545rfs0 wont drain or spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
It wont spin but keeps wanting to drain.started smoking deal bad.
i have a frigidaire washing machine and the tube wont spin and it filled the room with smoke. what could be wrong with it? i checked the belt and it is good so i dont know what could be wrong.
3helpful
My washer wont spin it washes but wont spin i have a Frigidaire Gallery
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
2helpful
2answers
Washer repair
The transmission might have locked up causing the motor to overheat.
Open Questions:
See all Frigidaire Gallery GLWS1339EC Top Load Washer Questions
Frigidaire Gallery GLWS1339EC Top Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
