Aeg m1180 -4-m keeps cutting out after five mins let it cool down and it will work again when it shuts down light fan and every thing will cut out except the main pilot light which stays on to the left of the clock in red
SOURCE: Oven cuts out after ten minutes and comes back after cooling down.
thermal cut out fuse, costs about £30, my company fits them for £78 all in in essex
The control switch on our AEG B3000, a similar oven, had burned contacts which prevented the fan from running in one selector position where the fan was to run when the heating element cycled off. The tech replaced thermostat which was not problem at all. If the fan does not run in this mode the heat stays at the top of the oven near the thermostat and prevents proper heat build up. Switching to 100% convection fan mode solved problem until switch replaced and all switch positions worked again. Hope technician will now refund for thermostat which was perfectly fine. Always check thermostat in boiling water before replacing.
SOURCE: aeg b3101 oven / grill cutting out
Ther are a couple of possibilities that could be causing your problem.
A thing called the safety stat could be cutting the oven out, it is designed to cut off the oven in the case of overheating This is what brings on the cooling fan. Sometimes they cut out prematurly for example you may not have enough vetilation, check for restricted or blocked vents.
The stat itself could be faulty again causing the oven to cut out,and then as it cools down it resets itself and so on and so on.
The thing to do after you hve checked evrything else is toichange the stat.
It is usually located on the top of the outer oven compartment, it is about 1" or so long with a feed in and out of it
Plz rate my solution.
Thanks, and merry xmas.
SOURCE: My oven keeps cutting out after 45 mins. The
not sure but it sounds like it is tripping on overload
SOURCE: My AEG B3101-4 oven works for about 30 mins, then
It is a safety thermostat that is cutting the oven off, due to overheating.
It could be that the external cooling fan is not working, or the cut out itself is faulty.
Check to see if you can hear the fan working.
This is usually located on the top of the oven , at the rear of the oven, on the top .
Hope this helps.
