Cannot print ? or / on my laptop only prints French e with the accent
SOURCE: How can I unlock the blue function keys on my HP Pavilion dv2000?
Hi, I had the same problem and found the solution on another website:
To turn on and off Bilingual blue keys:
Hit Ctrl + Shift + shift
(yes, both shift keys at the same time in addition to ctrl)
and that turns on and off the Canadian bilingual blue keys on HP lap tops.
It's so annoying and happens to me frequently. Hope this helps.
M
SOURCE: Weird French character key
This is a problem I haven’t stumbled on before and it bugged
me so I have a suggestion.
Open the Control Panel (generally on the Start menu)
Open the Regional and Language folder
Click on Languages tab
Click on Details
See if the keyboard layout is set to ‘US.’
Now, what I don’t seem to find is how to choose something
different without actually changing ‘Language’ itself.
Win ‘Help’ gave this result when searching on “changing keyboard
language:”
“You can switch to a different keyboard layout
or enter text in other languages without changing keyboards. However, the key
labels may no longer match the characters you are entering. Use Regional and
Language Options in Control Panel for changing languages and keyboard layouts.”
If this does or doesn't work, please post back as it might help others either do what you want to do or avoid paying any attention to me <grin>
SOURCE: question mark key always comes up as a french letter e -
I use 2 different keyboard types too.
Have you tried pressing [Ctrl]+[Shift] to change the keyboard type you are in. Even if you choose a default language in a program all other program will still use the other keyboard type, hope this helps.
SOURCE: French accent on Dell Laptop
go to the control panel - regional settings, and change your keyboard to french, mon ami:)
SOURCE: how to make french accents marks on a laptop that
You need to tell windows it has a french keyboard:
In the control panel, go to regional and language options.
Go to the keyboards and languages tab, click change keyboards. On the window that pops up, click on the general tab. You probably have just the us keyboard installed. Click add, then choose either english-canada or french-france, then click to add the french keyboard. Click preview to see where the accent keys will be (so you can find them). Now, select the french keyboard and click 'move up' so the french keyboard is above the us english one.
Voila!
Hope this helps. Post a comment if you get stuck.
Joe
