Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Closed door, door found open
SOURCE: Kitchen Aid Superba - door needs adjustment
there is two bolts oin the very front of the unit behind the kickplate the oiu can turn clock wise until there is a slight tile toward the back of the unit so that the cams on the doors will have a little bit of gravity to helop them stay shut.
Posted on Mar 26, 2009
SOURCE: kitchen aid open door sensor alarm keeps going off door is closed
Open door and turn power off then on twice. Then press the Overtemp reset.
Posted on Aug 08, 2009
SOURCE: Refrigerator Door won't stay closed
The lower hinge on each door
may have a door closing cam. It raises the door up ¼ inch when opening and this
assist in closing the door. If it’s wore out and doesn’t work the door may not
seal and the gasket can be damaged. Watch the operation of the door to see if
it rises up when opened.
Part 12 on this diagram is your cam.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=KSRB27FHSS02&productCategoryId=0165000&brandId=0593&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00006&componentDescription=REFRIGERATOR%20DOOR&documentId=O2030395&backToLink=Return%20to%20Sub%20Components%20list
Posted on Aug 19, 2009
Testimonial: "The most helpful and complete response I received. The link to the schematic was a great deal of help. You are a true Pro and I appreciate your help."
SOURCE: My refrigerator door comes open easily when the
Try to re-adjust the appliance so it is level and tips backwards slightly. You'll have gravity on your side to help keep the door closed. You will need help tipping the unit while adjusting the levelers underneath.
Also make sure the appliance is sitting on a solid surface and isn't somehow twisted, which will place stress on the box and possibly cause the issue you describe.
Make sure the unit is not overloaded and that the gasket surfaces are clean. After only 5 years, the magnetic gaskets should not be worn out.
Posted on Jan 27, 2010
SOURCE: refrigerator door won't stay closed
CHECK THAT THE BOTTOM DRAWERS CRISPERS AND SUCH ARE ON TRACK AND THE SHELF THAT THEY RIDE ON IS WHERE IT SHOULD BE. ALSO LOOK IF SOME CONTAINER IS CONTACTING THE DOOR, IT IS NORMALLY THE BOTTOM DRAWERS THE DOOR SEAL IS MAGNETIC. MAKE SURE THAT THE DOOR IS NOT CANTED WHERE THE BOTTOM OR TOP CONTACTS FRIG SEPARATE, SHOULD BE AT SAME TIME.
Posted on Mar 11, 2010
