Dryers Logo
A
Anonymous Posted on Sep 01, 2014
WERE IS THE RESET BUTTON ON HOTPOINT DRYER CDT 80
MODEL N0 CDT 80
Sam
Level 3:
  • Hotpoint Master 3,247 Answers
  • Posted on Sep 01, 2014
Sam
Hotpoint Master
Level 3:
Answers
3247
Questions
0
Helped
1305443
Points
10378
Not sure if all dryers have a thermostat reset. You can check your model (which might be CTD80 and not CDT80). Usually it can be reset if there is a small hole in the middle of the device where you can insert a tooth pick and press it.
Location of thermostats is at the back. Make sure the power chord is unplugged from the wall.
See this youtube video.
how to replace Hotpoint tumble dryer thermostat
1 Related Answer
Anonymous
  • Posted on Jul 15, 2008
SOURCE: ctd 80 hotpoint dryer
new door catch
Candy Condenser tumble dryer model GVS C9DCG-80 31100907
The E22 error code on your Candy Condenser Tumble Dryer model GVS C9DCG-80 31100907 indicates a problem with the drainage system. This could be caused by a few different things:
  1. Blocked drain pump: The drain pump may be clogged with lint or debris, preventing it from properly draining the water from the dryer. Check the drain pump and make sure it is not blocked.
  2. Drain hose: The drain hose that carries the water from the dryer to the drain may be clogged or kinked. Check the drain hose to make sure that it is not blocked or kinked.
  3. Drain filter: Make sure that the drain filter is clean and not clogged.
  4. Control board: The control board manages the dryer's functions and if it's faulty it can cause the E22 error.
To reset the error code E22 on your model, unfortunately, it seems that your model doesn't have a reset button or an option button to reset it. The best course of action would be to contact the manufacturer or an authorized technician for further assistance on how to reset the code and troubleshoot the problem. They will be able to diagnose the problem and provide you with a solution.
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
http://www.which.co.uk/news/2015/12/113-hotpoint-indesit-and-creda-tumble-dryer-models-pose-fire-risk-426557
http://www.itv.com/news/2016-04-18/hotpoint-dryer-fire-risk-which-models-are-affected
Feb 15, 2017 • Dryers
Where is the reset button on a CDT00 dryer
I assume you are speaking of a Hotpoint electric dryer based upon the model and question. There is no reset button on this dryer. Does it not heat or does it not tumble? Typically with these dryers, it is a thermostat that has failed if you are having a heat issue. Check this website;
https://www.youtube.com/watch?v=sfGInKA3yp8.
Jan 15, 2015 • Dryers
My Sears Kenmore 80 dryer will not turn on.
your dryer motor is worn out,replace it,the model number is inside the dryer door-mike
Does not work
Error code F10 indicates a faulty thermostat, or the common of the element is open circuit.
You need test the stats for continuity, also the element as well.
It is more likely to be the stats, you must, replace both and not just the one.
Check vents , clean filters
Remove the lower left filter, and wash it through with running water to thoroughly clean it.
Plz rate my solution.
Thanks.
8helpful
2answers
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 • Dryers
2answers
Not drying
Is it still under warranty? I've read that these machines are better left at the retailer...
Top Hotpoint Dryers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
