Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
It will shut off randomly and then just the box will come on for a minute then shut off agin and it just repeats this cycle. I can un plug it for awhile then plug back in and it will turn back on
Once it starts the cycle of shutting off there is no picture and the only light on the reciever on is the tv1 not the mode light as normal.
Posted by Dalton Stuckey on
3 Related Answers
Anonymous
  • 56 Answers
SOURCE: In single mode, my remote for TV1 works, but in
Your shared view is enabled. , press the menu button, then option 6 then option 2, disable shared view then select done. ( this can only be done in single mode) then go back to dual mode.
Posted on Nov 12, 2009
SOURCE: My dish network duel feed
Hi pappy63my name is Mike Houston of DISH Network and there are some steps that will getyour DISH Network remote to change the satellite channels. The first thing youwill need to do is press the System Info button on the receiver or pull out thesmart card from the receiver, with the remote press and release the SAT buttonand press the Record button and you will see the number in the white boxchange. I will leave a link to help with these steps. http://www.dishnetwork.com/SupportSection/remote-setup
Posted on Feb 13, 2011
raycalo
Ray Calo
  • 358 Answers
SOURCE: tv2 remote not working tv1 must be on
It sounds like the RCA cable is plugged into TV 2 ports on the back of the receiver.
Depending upon your receiver, towards the center on the back of the receiver, you have 3 rows of colored (2 - Red, White, and Yellow; 1 - Green, Blue, Red). The RCA for TV 1 should go in the middle row. Please let me know if you have further problems. Thanks.
Posted on Dec 16, 2011
DO YOU HAVE a manual for a woods e227659 TM-068-2 timer?
Woods TM-068-2
Indoor 7-Day Astronomic Timer
125V ac / 60Hz 15A / 1875W general purpose
8A / 1000W tungsten 500VA electronic ballast
15A / 1875W resistive 120V ac / 60Hz / 8,3A ballast
FEATURES:
• Up to 7 different programmable ON/OFF cycles, cycles repeat weekly.
• Programming fl8xibilify: u8hts fun on/off automatically at sunset/sunrise,
or at any programmed times you choose.
• ln Sunrise/Sunset programming mode, timer will automatically adjust the
programmed ON/OFF cycles to match current sunrise/sunset times.
• Timer automatically adjusts to daylight savings time
WARNING: TIMER IS INTENDED FOR INDOOR USE ONLY!
BEFORE YOU BEGIN PROGRAMMING THE TIMER:
This timer has in internal battery backup to save all programming.
  1. Plug the timer into wall outlet for 30 minutes to charge internal battery.
  2. After 30 minutes, unplug timer and press the RESET button with the tip of a toothpick or similar object to clear the memory.
TO SET THE CLOCK:
  1. Press SET. PRESS +/AUTO or -/RDM to set the current year.
  2. Press SET. PRESS +/AUTO or -/RDM to set the current month from 01 to 12.
  3. Press SET. PRESS +/AUTO or -/RDM to set the current date.
  4. Press SET. Daylight savings mode (DST) will appear on the bottom of the display. PRESS +/AUTO or -/RDM to set mode to either DST AUTO or DST OFF.
  5. Press SET. PRESS +/AUTO or -/RDM to set the current hour. To change between AM and PM, press +/AUTO or -/RDM 12 timers.
  6. Press SET. PRESS +/AUTO or -/RDM to set the current minute from 00 to 59.
  7. Press SET. PRESS +/AUTO or -/RDM to set the Astronomic function to your zone - North (nor), Central (cen), or South (sou).
  8. Press SET to view the sunrise time. To adjust sunrise time press +/AUTO or -/RDM. To go back to the default sunrise timer press ON/OFF.
  9. Press SET to view the sunset time. To adjust the sunset time press +/AUTO or -/RDM. To go back to the default sunrise timer press ON/OFF.
  10. Press and hold SET for 5 seconds to exit clock setting mode.
Note: The timer allows a maximum of 7 programmable ON/OFF cycles.
To program the first ON/OFF cycle: Press SET repeatedly to scroll through setting the clock mode.
  1. Press SET to display ON 1 setting.
  2. Press +/AUTO or -/RDM to select day or group of days you want for cycle 1. Scroll to select either every day, any individual day, weekdays only, or weekends only.
  3. Press SET. Set ON hour by pressing +/AUTO or -/RDM to scroll through and choose hour AM or PM, or Sunrise/Sunset icon for first ON setting. Note: To select Sunset or Sunrise for the ON time, you must scroll through all the AM and PM hours first. If you select Sunrise/Sunset as the programmed ON time, press SET to continue programming OFF setting.
  4. Press SET. Press +/AUTO or -/RDM to set ON minute from 00 to 59.
  5. Press SET to display OFF 1 setting.
Repeat steps 2-4 to program desired OFF time.
To program additional ON/OFF cycles: Repeat steps to create additional ON/OFF cycles (ON 2-OFF 2, ON 3-OFF 3, etc.) up to a maximum of 7 different ON/OFF cycles.
Press and hold SET for 5 seconds to exit programming mode. Note: During programming, if no button is pushed for 30 seconds, the timer will automatically return to standby mode. Press ON/OFF to cancel any setting.
Sun tracking technology: Timer adjusts automatically to changing sunrise and sunset times in sunrise/sunset mode is chosen for any programmed ON or OFF time. For example, if you program a cycle to turn ON at sunset and OFF at 10:00 pm, the timer will automatically adjust ON (sunset) time as sunset time changes throughout the year (and will always turn off at 10:00 pm as programmed).
IMPORTANT! REVIEW PROGRAMMED ON/OFF CYCLES: Press SET to advance through all programmed ON and OFF settings. Make sure there are no overlapping ON or OFF times. Stop at any programmed setting you want to change.
To operate timer: Press +/AUTO until AUTO appears in display. Timer must be in AUTO mode for programmed settings to operate. Plug appliance (such as lamp) into timer and plug timer into wall receptacle.
IMPORTANT: Appliance must be turned ON or be in the ON position before plugging it into timer.
SECURITY (RANDOM) MODE: To operate a plugged-in appliance (such as a lamp) in a random pattern while you are away, to simulate actual use: press -/RDM until RDM appears in display. In Random mode, plugged-in appliance will turn on and off at random, approx. +/- 30 minutes from the programmed settings.
To cancel Random mode, press ON/OFF until RND disappears from display. Timer will now function using your previously programmed settings.
DAYLIGHT SAVINGS (DST) MODE: If timer is in DST AUTO mode, clock time (and sunrise and sunset time) will automatically increase 1 hour on the second Sunday in March at 02:00 am and decrease 1 hour on the first Sunday in November at 02:00 am.
TO OVERRIDE THE TIMER: Press ON/OFF until desired mode is displayed:
ON: Programmed settings will be overridden; the plugged-in appliance will remain on
OFF: Programmed settings will be overridden; the plugged-in appliance will remain off
AUTO ON: Turns plugged-in appliance on immediately until the next programmed OFF time. Press ON/OFF until ON displays on the screen, then press +/AUTO and AUTO will display on the screen.
AUTO OFF: Turns plugged-in appliance off immediately until the next programmed ON time. Press ON/OFF until OFF displays on the screen, then press +/AUTO and AUTO will display on the screen.
RDM ON (Random ON): Turns plugged-in appliance on immediately until the next random off. Press ON/OFF until ON displays on the screen, then press -/RDM and RDM will display on the screen.
RDM OFF (Random OFF): Turns plugged-in appliance off immediately until the next random on time. On/Off times will vary +/- 30 minutes from the programmed settings. Press ON/OFF until OFF displays on the screen, then press -/RDM and RDM will display on the screen.
Consumer Support (800) 561-4321
www.colemancable.com
Dec 12, 2017 | Woods Hardware & Accessories
2005 ford escape starts and runs fine for a few miles then dies and it has to set a few minutes before starting again then it'd a repeat of above
Hi Tim, The link below is a short youtube video showing how to test and fix a car that shuts off randomly, Hope this helps.....CHEERS..
Fixing Car That Shuts Off Randomly
Apr 04, 2016 | Ford Cars & Trucks
Would a bad heating element make the dryer shut off and lights flash too?
no, unless it is maybe causing a short somewhere like the healing element wires touching metal. does it start agin after shutting off? may have a bad cycling thermostat or worse yet if its shutting off after bout 25 minutes u may have a bad motor windings problem if it will not start again right away but in about an hour it does start? BAD WINDINGS
Mar 01, 2015 | Dryers
I took my dryer apart and found a staple on cushion of barrel. I did not remover circuit board and may have damaged something. When torn dryer on the timmer light shimmers and will only dry for 30 mi
sounds like u may have a motor winding going bad will usually run 20-30 minutes then shut off and if u run agin right away it will run 10-15 minutes and shut off agin. run an hour later and u will get 30 minutes or so agin? or u may have bad venting causing an over heating prob
Oct 28, 2014 | Maytag MDE2400AYW Neptune Electric Dryer
I have a Gas Whirlpool dryer model GGQ9800PW3. The dryer stops before the cycle is complete. It can be restarted, but again it will work for a while then shut off. I changed the temp setting from med
Oh oh sorry to say this but sounds like the motor windings are going bad? does it shut off then about 30 to 60 minutes later u can start agin? a bad cycling thermostat or thermistor could be culprit but I doubt that in ur case.
Sep 27, 2014 | Dryers
Washer stops several times in the middle of cycle
possibly it could be your un-balance switch getting very sensitive to any type of movement of the machine, normally they only actuate during the spin cycle when you have a very off balanced load of clothes
Oct 03, 2009 | GE Profile Prodigy WPSE4200A
Posessed TV!
drdye- this may be a simple problem,most people use the remote all the time and hardly use the panel buttons .Try working the panel buttons, press each one repeatedly a few times you may have a bad one causing problems. Let me know if this works,we can try a few things. cooltek Feb29/08
Feb 20, 2008 | RCA 14F512T 14" TV
Powers on and off randomly
one of your tubes are bad...call tech
Nov 26, 2007 | Toshiba TP55H60 55" Rear Projection...
Magnavox 15
IT IS YOUR POWER SOURCE HAD SAME PROBLEM CHANGED POWER PLUG HAS HOT TURNED OFF SINCE
Oct 10, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
Posessed TV!
microprocessor circuit----possible bad solder connect--examine w/magnifier--
Oct 05, 2007 | RCA TruFlat 27F520T 27" TV
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
106 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
