Why my top 3 shelves are not frozen?
SOURCE: top is frozen lower shelves food is dethawing
One of two things is going on here, either the door is not closing properly (or some one left it open), check the seal all the way around especially at the bottom.
Or most likely you have a refrigerant (freon) leak that has left the charge low enough that you are unable to get it to cool throughout. A leak on this type of unit is usually in the evaporator in the corner where a weld was made. The evaporator is about $189.00, with refrigerant a new drier and supplies I bet it would run about $450.00 to repair.
SOURCE: meat on top two shelves
hi... is the evap fan motor running in the freezer ? if it is then check the the evap coils if it is completely frosted then u need to check the defrost timer .if that is good then check the defrost limiter that is on the evap coils and if that is good then u got a bad defrost heater. now if there is frost only on the bottom or top of evap coils u may have sealed sys problem if u got an ? feel free to write me..
