Unique customer Registration for MYOB Plus 11 I used MYOB 7 for years, and it worked all the way up to Windows 7 - now it won't even start. Its time to leave. I have a copy of MYOB Plus 11 that seems to...
Or, just get a version of windows 7 (look for "Windows Anytime Upgrade" on your computer) that can run a virtual XP machine (Pro or Ultimate versions), then download and install the virtual PC hyper-viser kernal and the XP Mode virtual machine.
Next, install your old copy of MYOB 7 into the XP mode virtual machine, copy your data files, and it should work....
EXPLANATION OF "WHY": MYOB 7 was actually meant to run on windows 95/98 machines, and this wasn't a problem in XP, because it could run a program that would basically emulate all of the win95/95 API's, under which MYOB 7 could run. Starting with windows vista, those old API's and emulation programs were basically tossed. Running the program under a virtual XP machine will give your old programs, like MYOB 7, access to those old API's. BTW, once the program is installed, it should auto register with windows 7. After which it will run in the win 7 interface almost as if it were a native program (will take longer to load as it has to load XP OS too).
One note, any custom forms (invoices, etc) may not work after copying them to the new installation of MYOB. Change their file attributes from Read Only (uncheck that box from within the files' properties dialog, via windows file explorer).
Oh, you'll definitely want as much RAM in your computer as you can get in there. XP mode will take a minimum of 512MB, but it'll be slow unless you set it up for at least a gig of ram.
