Question about IBM System Storage TS3200 Tape Library Model L3H - Tape library - 17.6 TB / 35.2 TB - slots: 44 - LT... (3573L3H) Tape Drive
IBM ts3200 tape library default service password
Jimmy Smith
    Sergeant:
  • 198 Answers
You will need to contact IBM support and after providing proper I.D. verification , they should be able to give you a password which you will be able to use. Due to security issues with stored info, you will have to provide the proper ID info as the original purchaser. Best Wishes
Posted on Sep 01, 2014
1 Related Answer
Anonymous
  • 78 Answers
SOURCE: I want to know about IBM TS3200 tape library.
trial and learn...
place only one tape drive in a deck and tell it to do a backup till it doesnt give an error. then move to the next drive.
Posted on Jun 10, 2010
Testimonial: "Thank you!"
IBM TS3200 Code 9F 08
The manual is online with IBM.
Chapter 8 explains the error codes and 9F (mean Error code) means Rotation range out of specification 08 9sub error code) means error during rotation initialisation, get range failed.
Then the manual says: "Isolating a library controller card versus accessor enclosure problem" on page 7-11
But I guess you better look it up yourself. If you don't have any parts, you have to contact IBM.
Look yourself? start in chapter 8, page 225 of the manual under this link.
http://publibfp.dhe.ibm.com/epubs/pdf/a320545c.pdf
Feb 16, 2014 | IBM System Storage TS3200 Tape Library...
Robotic hardware error and I/O station status shows open
A physical obstruction in the path of the robot's motion. Examples
include tape cartridges that are extending from the picker assembly or
from a storage location, as well as tape cartridges or debris that may
have collected on the floor of the library.
2. A large number of electrical hardware failures. Firmware or hardware
detects that motion control is not occurring properly (encoder issues,
motor driving circuits, motor winding issues, etc.)
3. A relatively small number of mechanical hardware failures that do not
result in the detection of a complete obstruction, but where motion
control generates robotics firmware error codes (contamination or damage
to encoder wheel, high friction, etc.).
Possible FRUs is Robot Assembly
Sep 01, 2013 | IBM System Storage TS3200 Tape Library...
Inventory lost - source probably empty
dear friend send me the solution i have seen the same recently with mine too
Mar 11, 2013 | IBM System Storage TS3200 Tape Library...
Error 9E 09
Error 9E 09
9E : Elevator range out of specification
Primary: Library Enclosure
Secondary: Library Controller Card
09 : Error elevator init
Nov 02, 2012 | IBM System Storage TS3200 Tape Library...
HE: drive broken: needs repair
Then raise a call with IBM Hardware:
How do I create a PMR (aka Service Request) for support?
http://www-01.ibm.com/support/docview.wss?uid=swg21507639
Apr 17, 2012 | IBM System Storage TS3200 Tape Library...
Web user interface timeout please log in again message over and over even after I log out and try to log back in
This may be caused by a bus level communication problem, try a restart. Power down the computer, power down the library, power up the library, wait for the library to finish initialization and verify from the control panel it is in an online/ready state, power up the computer.
Jan 12, 2011 | IBM System Storage TS3200 Tape Library...
IBM TS3200 is a single tape library or multiple?
ibm ts3200 is a single tape library with 2 versions, 2U and 4U, the 2U version support 2 drives HH and the 4U version support 2 FH and 4HH.
Jun 11, 2010 | IBM TS3200 LTO4 TAPE LIB W/ SCSI (3573L4H)...
IBM TS3200 has how many tapedrive exactly
Hy ,according to manual it can have up to two drives.
Jun 10, 2010 | IBM TS3200 LTO4 TAPE LIB W/ SCSI (3573L4H)...
I want to know about IBM TS3200 tape library. In that which library is mapping with which tape drive?
trial and learn...
IBM System Storage TS3200 Tape Library Model L3H - Tape library - 17.6 TB / 35.2 TB - slots: 44 - LT... (3573L3H) Tape Drive Logo
Top IBM Computers & Internet Experts
Michael Thomas
Michael Thomas
Jax Planet
Jax Planet
efs_perpends
efs_perpends
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
