Door handle loose, do you have to remove inner liner and if so how?
SOURCE: door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
SOURCE: refridgerator door handle
The entire handle slides upward and out to detach from the door. There are two screws attached to the handle which can be tightened once the handle is off. Those screw heads are what reattach the handle to the door by sliding them through the door bracket opening, where they follow a short channel down leaving the handle secured again.
SOURCE: Refrigerator won't fit thru door.
I ran into the same problem when I moved into my old house. the door way was to small, so I had to take both doors off the refrigerator to get it through the doorway. But I found out when I moved out of the house, that I was able to open both doors and wiggle it through the doorway. It was a hassle but it was alot easier that removing the doors. Good luck.
SOURCE: My side by side refrigerator handles are loose (Whirlpool gold)
Hi, Most newer models have a screw behind the plastic cover on the handle. Take a good look at the handle and see if the cover can be removed. It should just snap on. If not, please get me you model # and I can assist you further.
Thanks
Vic
SOURCE: I have a whirlpool gold side by side with ice and
See if you can unscrew the handle at the bottom, and slide it off the top bracket. Then you should be able to tighten the top screws and re-install the handle.
