Mountain Shimano 050 Front Bike Derailleur Bicycle Parts 20 Logo
A
Anonymous Posted on Sep 01, 2014
How to adjust front derailleur on a shamano 050 ?
How to get it to select all three sprokets
Michael C
Level 2:
Novelist:
  • Expert 176 Answers
  • Posted on Sep 01, 2014
 Michael C
Expert
Level 2:
Novelist:
Answers
176
Questions
Helped
51850
Points
501
The front part is a bit tricky to change sprockets. I have a mountain bike with three sprockets, I also have difficulty with changing them. It all depends on the design of the changer. I am able to change from large sprocket all the way to the smaller but from the smaller sprocket to the second is okay but going into the third (large) sprocket is a real problem and no matter how hard an adjustment I've tried, it still doesn't want to go to the far end. Example, if it is in the smaller sprocket, it changes okay to the middle sprocket but it will not fully change in the larger sprocket because the cable doesn't fully push the changing bracket far enough to roll the chain on it. So, as with myself having same problem, I'd say, never buy a bicycle that doesn't change the front sprockets with ease. But while you have one of these three front sprocket bicycle, you have two options. Try and put the bicycle on a stand and adjust the changer's screws so that it can reach the far end where the large sprocket is, or in another case -where the smaller sprocket is, depending where your problem lies, the larger or the smaller sprocket). Remember that the air test is different to the road test. On the air test (bicycle on stand) the changer may be able to change sprockets but on the road the chain is heavily under tension and may not over-jump into the larger sprocket, but down-jumps into a mid or smaller sprocket quite easily. So, the best thing you can do is to not to apply force to the pedals to relieve the chain of any tension so that it can jump over the larger sprocket. But apply tension to the chain, such as 'accelerating', and it will not over-jump the larger sprocket with ease. However, if you change down to a smaller sprocket while 'accelerating', it usually changes without problems. The other option you can use is to sent the bicycle to a store and have it fixed there. Work is guaranteed and you can be sure your worries will be over.
1 Related Answer
Anonymous
  • 8546 Answers
  • Posted on May 02, 2010
SOURCE: I have td one derailleurs front and back on my
Check out his site. It has everything you need to understand these adjustments. The 'regions' are parts of the bike.
http://www.parktool.com/repair/byregion.asp?catid=53&imageField2.x=37&imageField2.y=13
1helpful
How do you adjust a shimano xtr m9000 front derailleur from 3 speed operation to 2 speed operation as there is no selecter switch
You have to do it at the front derailleur. You adjust either the inner or outer limit screw so that the derailleur can only go to two of the chainwheels. Front Derailleur Adjustment
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
How do i connect cable to front derailer on shimano comfort 050 gears ?
I'm confused, You show a rear derailleur and ask a question about a front one? Cable for front usually goes from bottom up, through an eyelet then into the holding bolt. Make sure your cable is in the low gear setting and your chain is on the smallest gear. Pull cable tight, and secure. If you have problems, take your bike to the nearest bike shop, they can help you
2answers
Ezip
Since you didn't specify which derailleur needed adjusting, I have included links to adjusting both the front and rear derailleurs.
Park Tool Co ParkTool Blog Front Derailleur Adjustments
Park Tool Co ParkTool Blog Rear Derailler Adjustments derailleur
Apr 13, 2014 • Cycling
Front chain rack sistem adjustment
I am assuming you are referring to the front derailleur. Here is a link to adjusting the front derailleur:
Is this derailleur 3 speed?
No, it is a front derailleur, and must be able to accomodate 3 front chainrings. Where did you get the derailleur, from what bike? They are not universal fit. A lot depends on your shifter to work and the size of your frame.
Chain coming off fron gear when coasting or trying to pedal backwards? Local bike repair shop indicated that a bearing maybe shot but that they couldn't replace the front gear unit.
Oh, it is too bad you are in the Bronx. i'd have that fixed right quick. There are probably a pair of culprits at work here. One, your derailleurs no doubt need adjustment. Two, your rear derailleur hanger may be bent. These two can both cause the problem. Start with the rear hanger, because that will be easier to see.
Flip the bike onto the bars and saddle and take a look at your rear derailleur. Is it going straight up and down and is it aiming straight with your frame? If it isn't, you have found your problem. The hanger needs to be straightened. This can be done without any tools if you have a good eye. Hold the derailleur by the body and bend it to make the alignment good with the cassette. If this is NOT the problem (but i really think it is) then here is a walk-through on adjusting your derailleurs and hopefully this will solve it.
Here is how to adjust the rear (first):
-Set your front gear to its middle position.
-Shift the rear into the highest gear.
-Disconnect the derailleur cable.
-Screw the barrel adjuster on the shifter (or down tube if it is a road bike) to fully turned in clockwise.
Screw the barrel adjuster on the rear derailleur to its halfway point.
-On the back of the rear derailleur you will see two screws. One will be marked "H" and the other "L". These mean high and low. Adjust high to get your jockey wheel on your derailleur perfectly centered over the smallest cog on the cassette. Manually shift by pushing the derailleur (while cranking the pedals) to the largest cog (1st gear) and set this stop on the derailleur "L" where the jockey wheel is over the cog, but past it where it would be touching the outside of the cog if they were side-by-side.
-Pull the derailleur cable taut and re-tighten it.
Shift the rear to the middle gear and adjust the derailleur using the barrel adjuster to center the jockey wheel directly over the cog it should be.
-Now shift up and down the cassette, cranking as you go and in every gear, back-pedal to make sure there is no problem with the gears hopping. If they do, adjust as necessary with the barrel adjuster.
Here are some tips for the front:
-Shift into low gear on the front and rear derailleurs. Make sure the chain is not rubbing on the front derailleur. If it is, adjust the screw marked "L" until the chain just clears the derailleur but does not touch it.
-Now shift the front into the middle gear and while it is still in the low gear in the back, crank to make sure the chain is not rubbing on the front derailleur. If it does, adjust the tension of the cable with its barrel adjuster.
-Shift the front into high gear and shift the rear to the highest gear, cranking as you shift. If the chain is not rubbing, you are all set.
Sep 16, 2009 • Cycling
1helpful
I'm trying to adjust the shimano gearing on my trek bike and am having a little trouble
Front or rear? What is it doing?
Flip the bike over onto the handlebars and saddle and let us fix it.
Sep 02, 2009 • Cycling
3helpful
Adjusting front derailer
Typically adjusting the front derailleur is a matter of adjusting the two adjusting screws on the derailleur. So turn the bike upside down. It should sit on its seat and handle bars. Find the two adjusting screws one will prevent the derailleur from traveling too far out preventing the chain from coming off. The other screw prevents the derailleur from traveling too far in keeping the chain from falling off that way. Now once you have found the screws slowly start turning the pedals like it was being ridden. Move the derailleur out as far as it will go if you see the chain is about to come off adjust the screw. Do same for inside screw. Now move the back derailleur all the way in and retest front derailleur, repeater with rear derailleur all the was out. Hope that helps. Oh, the back derailleur adjusts same way.
Top Mountain Cycling Experts
john h
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Mountain Cycling Expert? Answer questions, earn points and help others
