Printer is automatically paused as we load the paper
SOURCE: wrong adjustment using epson LQ-2180
Check to see if the pinch roller is set for standard sheet feeding the printer must feed by the tractor feed only.Does the paper get damaged when you try to feed or reset the page beginning, What we are looking for is a piece of one of the sheets loged in the pinch roller.Also check the pressure adjuster on the right side if you are not using multiple copie printing it should be set to medium . Let me know what you found... Be mucho blessed... Mark
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
SOURCE: my printer EPSON LQ-2180 send me an error code "paper out"
Hi Soulen , This link is very interest and useful for your type of printer : http://files.support.epson.com/pdf/lq2180/lq2180pg.pdf
and also for driver open this link : http://www.driverstock.com/Epson-LQ-2180-driver-download/23-26-3157-53410/index.html
SOURCE: epson lq-2180 printer pause light continously on
if u use up tractor use down tractor or inverse the operation
coz your problem is in paper sensor in up or down printing
