Samsung In Box Galaxy S 3 S Iii S3 White Sch-i535 16gb Verizon 4g Lte Logo
Question about Samsung In Box Galaxy S 3 S Iii S3 White Sch-i535 16gb Verizon 4g Lte
How do i set a new password on my gmail account
Screen comes up typed incorrect password and cannot get to a screen to change the passwork
Devon Koning
    New Friend:
  • 3 Answers
Click on the button that says "forgot password?" or "reset your account" and then follow the directions to reset your password. Hope this helps.
Posted on Sep 01, 2014
1 Related Answer
Anonymous
  • 55 Answers
SOURCE: Hi, I have a samsung galaxy s and the lock
There are 2 solutions: 1. is to enter your google username (try just username and if not working add [email protected]) and in password field to enter number 0 that is number ZERO.
2. If other is not working you will have to reset to factory settings your phone, loosing all your data except on SD card.
For resetting your phone to factory settings you will have to enter recovery mode. Here are the steps: First try to enter Recovery Mode. There are a few ways to enter in Recovery Mode -> video link.Once in a recovery you can easily choose Factory Reset. On upper link you can find three ways to do it, and one way of doing it goes like this, it usually works:
1. Power Off your phone2. Press and hold Volume Up button + Power button + Home Menu button (just hold all three buttons at same time until logo appears)3. Select Wipe all data / Factory Reset (you select it with Volume Up and Volume Down buttons and execute it with Power button or in some cases with Home Menu button).
If you watch videos you will find same thing.
Posted on Aug 16, 2011
tip
Gmail on outlook!
To use your Gmail e-mail account in Outlook, you must first make sure POP3 support is enabled in Gmail, and then you can add it to Outlook.
Log in to your Gmail account.
At the top of any Gmail page, click Settings.
In the Mail Settings window, click Forwarding and POP.
I don't see Forwarding and POP
Gmail is turning on POP3 support for users in phases. If Forwarding and POP does not appear, your Gmail account cannot be configured for POP3
support.
In the POP Download section, select Enable POP or all mail or Enable POP only for mail that arrives from now on.
Click Save Settings.
In Outlook, on the Tools menu, click E-mail Accounts.
Click Add a new e-mail account, and then click Next.
Click POP3, and then click Next.
Under User Information, do the following:
In the Your Name box, type your full name the way you want it to appear to other people.
In the E-mail Address box, type your e-mail user name followed by @gmail.com.
Under Server Information, do the following:
In the Incoming mail server (POP3) box, type pop.gmail.com.
In the Outgoing mail server (SMTP) box, type smtp.Gmail.com.
Under Logon Information, do the following:
In the User Name box, type your full e-mail address, including @gmail.com.
In the Password box, type your password.
Select the Remember password check box.
Note You have the option to have Outlook remember your password by typing it in the Password box and selecting the Remember password check
box. Having Outlook remember your password means that you won't have to type your password each time you access the account; however, it also
means that the account is vulnerable to anyone who has access to your computer. Use strong passwords that combine upper- and lowercase letters,
numbers, and symbols. Weak passwords don't mix these elements. Strong password: Y6dh!et5. Weak password: House27. Use a strong password
that you can remember so that you don't have to write it down.
Click More Settings.
On the General tab, under Mail Account, type Gmail.
Click the Outgoing Server tab, and then select the My outgoing server (SMTP) requires authentication check box.
Select Use same settings as my incoming mail server.
Click the Advanced tab, and then under Server Port Numbers for both Incoming server (POP3) and Outgoing server (SMTP), select the This server
requires an encrypted connection (SSL) check boxes.
Change the Outgoing server (SMTP) port number to 465.
The Incoming server (POP3) port number should change automatically to 995 when you select the This server requires an encrypted connection (SSL)
check box.
Click OK.
To verify that your account is working, click Test Account Settings. If there is missing or incorrect information, such as your password, you will be
prompted to supply or correct it. Make sure your computer is connected to the Internet.
Click Next, and then click Finish.
Notes
Do not select the Log on using Secure Password Authentication (SPA) check box.
Unless specified by Gmail, all server and address entries are typed in lowercase letters.
This works for both Outlook 2003 and 2007!
I have sony vio laptop windows7 I forgot passwork ,How can i reset passwork thanks!
1. put windows 7 bootable dvd on your dvd rom
2. when you see the install windows screen type "SHIFT" + "F10"
3. now you can see the Command prompt (CMD) and type the following command
regedit.exe
Press "enter" key
4. now you get register edit window, after select File and click import
5. now you can see import registry file window
6. click computer and open c: drive on your registry file window
7. now open windows > system32 folder
8. change to " *.reg " to " all files "
9. now find and rename "sethc" file in to "sethc1"
10. now copy and paste the "cmd" file and you get "cmd copy"
11. rename "cmd copy" in to "sethc"
12. and close all open file and restart your computer
13. now after boot the windows you get password screen
14. after press " Shift " key continuously
15. now you can see CMD screen (dos screen) and type following command
net user
press enter key
now you can see user account on your pc (find out which account you need to reset password and type following commands
net user youraccountname 0
16. net user is dos command
youraccountbane is username
0 is (zero) new password
17. now closed CMD screen (DOS screen)
18. type 0 on you password box and enter
3answers
How do I change my password?
To change your Gmail password on a phone or tablet:
  1. Go to accounts.google.com/EditPasswd.
  2. Type your current password and your new password.
  3. Touch Change password.
To change your Gmail password on a computer:
  1. Open Gmail.
  2. Click the gear in the top right.
  3. Select Settings.
  4. Click the Accounts tab at the top.
  5. Click Change password in the "Change account settings" section.
  6. Type your current password and your new password.
  7. Click Change password
Hope that helps!
Jan 23, 2014 • gmail.com
1helpful
I forgot my Pass word,I am locked out of Face book, Yahoo.com and Gmail.com
Start with Facebook Password
Suddenly you attempt to login to your Facebook profile.
Perhaps you have simply forgotten your password or worst case your Facebook account security has been compromised.
Having had this happen to me, I can help you reset your Facebook password and restore your peace of mind.
You will be back networking with your friends, family and coworkers in no time.
Go to your computer bring up the Facebook login screen like you normally would.
Do not fill in any information.
Click on the link above your Facebook user name and password that states forgot your password. This brings you to a different screen.
Fill in the email address associated or on file with your Facebook account.
If you cannot remember, keep trying different email addresses until you do.
Click enter and a Facebook reset link will be sent to your email so you can recover your password. It usually takes up to 5 minutes.
Check your spam email folder if the email does not appear in your inbox.
Click the link in your email and answer any security questions by Facebook.
This brings back to the Facebook website.
Reset your password with a phrase you will remember mixed in with 1 to 2 numbers or more. Record this in a notebook or on a safe place.
Use a different password than you would for your email.
This decreases your chances of having both websites compromised.
Yahoo Email Password
When you sign up for a free Yahoo! account, you gain access to the extensive features of the Yahoo! community and receive a free email account.
As with any account, it is a wise idea to change your Yahoo! password a few times a year in order to ensure its security.
Knowing where to go in Yahoo! to change your password will allow you to do it quickly.
Sign into your Yahoo! email account.
Click on your Yahoo! name at the top of the webpage to access drop-down options.
Select the "Profile" option.
Your account page will open.
Place your cursor over "Account Info" in the toolbar.
Options will again drop down.
Click "Change Password."
Type in your current Yahoo! email password in the first text box.
Enter your new Yahoo! password in the lower two text boxes.
Click "Save."
Your Yahoo! password is now changed.
Reset My Gmail Password
Google introduced Gmail on April Fool's Day in 2004.
The company first gave out 1,000 accounts to Google employees, friends and family members to test out the new email system.
Now, Gmail is a common and popular email application for users around the world thanks to its ease of use, high capacity and wide range of functionality,
Sign in to your Gmail account with your user name and password.
Click "Settings" in the upper right-hand corner.
Click on "Account and Import," then click "Google Account Settings."
A new window will open.
Click "Change Password" under "Personal Settings."
Type your current password, then type your new password.
Type the new password again for confirmation.
Click "Save."
Forgot my gmail password
Click "Save."
Put in wrong password on the phone too many times, now i cant log in to my google acct on it either, its just stuck at the same spot
What Brand and Type of phone ??..
Phone password or google account password ??..
Im thinking iphone ?
Although a passcode limits your iPhone to authorized use only, protecting your vital personal information, if you forget it, you can't use your phone until you enter the correct code or revert your phone to the default factory status.
Apple provides ways to resolve a forgotten passcode problem and improve the iPhone's security.
Wrong Passcode
When you enable iPhone passcode security, the phone requires you to enter the code to display the home screen.
By default, when this protection feature is enabled, you'll be prompted to enter the passcode to turn on or restart the iPhone, wake it or unlock the screen.
When you enter the wrong passcode, the "Wrong Passcode try again" message appears onscreen.
If you enter the incorrect code too many times, the iPhone will lock automatically and display the "iPhone is disabled, try again in 1 minute" message.
This disabling security feature is designed to protect it from unauthorized tampering.
If you keep entering the incorrect code, the iPhone will be disabled for a longer time.
Restoring iPhone
If you don't remember your passcode, unfortunately, there is no way to retrieve it.
Apple says that the only way to solve passcode problems is to restore the iPhone with iTunes.
Before restoring the phone, downloading and installing the latest version of iTunes will improve connection and decrease the chances of errors.
Unfortunately, restoring the iPhone erases saved content and clears custom settings, so create a backup copy of your files with iTunes before proceeding.
From there, you can restore your iPhone by clicking the "Restore" button on the device's "Summary" tab in iTunes.
When the process completes, you can change the passcode settings.
Changing Passcode Settings
iPhone allows you to not only create a new passcode, but specify the amount of time it should take before the screen locks after inactivity.
You can also specify whether you want to use a simple four-digit passcode or a longer one that can include letters and numbers.
Tapping the "Settings" icon on the home screen will bring up the phone's settings.
From there, tapping "General" and then tapping "Passcode Lock" will bring up the "Passcode Lock" customization screen.
Select the settings you want to use to protect your iPhone. The changes will take effect immediately or when the iPhone turns off.
Tips
After restoring your iPhone, create a passcode you'll remember easily.
While creating a longer passcode can increase the security on your phone, you can forget it easily if you don't write it down and store it in a safe place.
gmail password reset
Open the Web browser on your phone and navigate to gmail.com.
Tap "Can't access your account" located under the "Sign in" button.
Select "I forgot my password" and then click "Reset your password here."
Type your email into the "Email" text box and then type the random captcha into the captcha text box.
An email with your new Gmail password will be sent to your alternate Gmail address.
Follow the directions in the email to reset your password.
Type the new Gmail password into the loin screen on your Droid to unlock the account.
http://www.gmail.com/
I would like to change my password for my gmail account
Type the new password again for confirmation. Click "Save."
http://mail.google.com/support/bin/answer.py?hl=en&answer=6567
My gmail account is not opening
you may type your password incorrectly . resetting the password will solve your problem. goto login page click on forget password and follow instructions given by the g mail. after that you will get a box to type your new password. type new password ,submit it . now you can easily access your account easily by new password.
3helpful
Unable to log in
Just start a new gmail account...
Open Questions:
See all Samsung In Box Galaxy S 3 S Iii S3 White Sch-i535 Questions
Top Samsung Cell Phones Experts
Robert
Steve
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
