Question about Canon Pixma iP6600D InkJet Photo Printer
Why will paper will not feed on canon pixma ip6600d printer
5 Related Answers
Anonymous
SOURCE: Paper will not feed properly/one side of paper not feeding in straight
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 23, 2008
Anonymous
SOURCE: Canon Pixma MP160 paper will not feed
try the feed button which is usually on the front of the machine. press once
Posted on May 22, 2008
Paul Blum
  • 6 Answers
SOURCE: Canon PIXMA MP600 printer - paper feed
Issue: Paper feeds skewed
Solution: Clean The Paper Feed Rollers Using The Operation Panel - MP600
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
  3. Press the <HOME> (A) button.
  4. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the <OK> button.
  5. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press <OK>.
  6. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
  9. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
The above illustration shows a PIXMA MP500
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click here to return to step 2
Posted on Jun 12, 2008
Anonymous
SOURCE: problems with paper feeder-wont feed through-chews up paper
I HAD THE SAME PROBLEM A MONTH AGO. I LOOKED WHERE THE PAPER LOADS AND THERE WAS A PAPER CLIP JAMMED IN THERE. I HAD A HECK OF A TIME GETTING TO IT, BUT I DID. AND IT WORKS FINE. MAYBE SOMETHING IS THERE.
Posted on Feb 01, 2009
Anonymous
SOURCE: canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Posted on Nov 10, 2009
Paper will not feed through. The roll bar that normally grabs the paper will not move any quick fixes for this.
If you can get to the rollers, get some fine grit sand paper and rough up the surface a little (Make sure you do it even around the roller, and on all rollers).
I had a similar problem on an old Xerox multifunction fax / printer and it worked fine.
Good Luck
Apr 25, 2010 | Canon Pixma iP6600D InkJet Photo Printer
Trouble feeding paper into printer
call our technician on toll free no 18884276640
Jun 23, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Paper jams and won't feed well.
TRY TO REMOVE IT WHEN THE PRINTER IS OFF ALSO BE AWARE TO PUT THE PAPER WITHOUT MAKING ANY DEFORMATION OF THE PAPER WHILE INTALLING
Jun 08, 2009 | Canon Pixma iP6600D InkJet Photo Printer
I have an ip660d printer now i am experiencing a paper jam. my paper wont feed when i print my documents
loose the static and restart the whole system also check for the drivers .is it properly installed
if problem persists it means you should now take it to service center
May 08, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Grey sponge came out when I pulled a jammed paper out of printer
its the ink blotter it collects any excess ink when you load in new ink cartridges you can still use it but watch out for any spills ...
hope this helps... jedi-inc...
Feb 09, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Paper feeding crooked and jamming in my Canon IP6600D printer.
Try doing a thorough cleaning of all the rollers in paper path making sure that there also no scraps or obstructions in the path.
Aug 31, 2017 | Canon Pixma iP6600D InkJet Photo Printer
Paper feed
in the printer dialogue that pops up prior to printing choose the number of copies
Oct 14, 2008 | Canon Pixma iP6600D InkJet Photo Printer
4 x 6 photo printing
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=184&modelid=11864#SupportDetailAct
Jan 08, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Paper feed or pick up problems
The rubber paper rollers on your printer that picks-up paper may have wiered out. So try replacing them. This may occur when the rubber rollers get dirty also. In that case just cleaning them with a wet cloth will do the solution (no water drop should fall on the printer assembly).
Jan 06, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma iP6600D InkJet Photo Printer Logo
143 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
