Revs up and down at full throttle and then it will not idle down at shut down.i have to choke it for it to die
Are you saying that it surges at full throttle and wont idle down or shut off? If so it is likely not a governor problem. Surging is a lean condition. Some models, particularly yard machines, will surge no matter the adjustment unless under a load. If it were a governor issue it would run faster and faster beyond full throttle. IF it wont idle down check the throttle control and throttle linkage and check for a sticking throttle shaft before suspecting governor. Not shutting off could also be in the throttle control. A ground clip is in the control. if the tab is not engaging the clip or the wire is not connected then the motor will not ground. Check those things before messing with the governor, especially if the machine was running good and no one has messed with it yet. Governors don't just come out of adjustment by themselves.
