I've got an older telly (panasonic viera) and a new samsung dvd-player which came with a remote control. the remote has got four buttons which allow to control a tv, but so far it doesn't work. apparently a code is needed. anybody know the correct code?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
SOURCE: I need to find out how to program my samsung RS-105N remote control.
The picture you have is a Directv universal remote.If that is correct.
Turn your Tv on.
Press and hold the TV and SET button until the TV button lights up. 4 seconds or so.
Release the buttons.enter one of the 3 codes below.If the TV turns Off you have the right code,press the TV button to lock the code in.repeat if the code does not turn the TV off
for Panasonic the codes are 034 or 080,056, 164
SOURCE: code to control my Viewsat9000HD on Bose remote not working at all
Have you tried changing the codes in the system setting?
SOURCE: Remote Codes for Commtel Control Freak and JVC
0053, 1253, 1923 if those don't work, I have others.
SOURCE: need control code, to operate dvd samsung
Yes. I found the code. To operate Samsung HT-Z 310 with a remote control of Samsung TV, You have to turn off DvD, and then select Dvd on the remote(press the dvd button), press SET on YOU
remote control, input the CODE(020). For different Samsung dvd. you can try.codes from 000-to 080. The DVD button must blep three times. After that swich on Dvd. Enjoy....
1. Turn on the device you want the remote to control; this can be your television, DVD player, or VCR.
Press and hold the appropriate mode button for the above device, until all the other mode buttons light up.
Hit the blank power button.
Press the up arrow on the remote repeatedly until the device turns off.
Hit the "#" button to lock in the code.
