Question about Kitchen Appliances - Others
How can i order the kernel tray for my popcorn machine?
Angel
    Problem Solver:
  • 7 Answers
Which model do you have? Once you have that, call the number on the back of the instruction manual.
Posted on Sep 01, 2014
5 Related Answers
Anonymous
SOURCE: Pop corn doesn't pop
stupid
your not supposed to put it in the refrigerator!
Posted on Jan 28, 2009
Bob Citizen
  • 520 Answers
SOURCE: RETRO POPCORN MACHINE
http://www.nostalgiaelectrics.com/
Posted on Feb 13, 2009
Anonymous
  • 109 Answers
SOURCE: How much oil and popcorn kernels to use in gold medal machine
Try one ounce of oil, 1/2 teaspoon popcorn salt and 1/2 cup of popcorn and see how much it fills your machine and adjust quantities from there. This will usually fill a wok size bowl.
Posted on Mar 29, 2009
mohammed387
mohammed marika thambi
  • 1952 Answers
SOURCE: heat lamp for goldrush popcorn machine
www.thefind.com/.../info-popcorn-machine-maker-poppe click this link
Posted on Jul 23, 2009
rickead1
Rick Ead
  • 1998 Answers
SOURCE: Gold Medal Products Whiz Bang
Have you checked to assure that the warmer switch and the kettle heat switch are both functioning properly? Also the timer on the bucket seasoning pump control box determines the length of time the heat element of the bucket pump is at HIGH HEAT i also suggest you take a look at this pdf of the manual of your machine under the troubleshooting guide area if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
http://lib.store.yahoo.net/lib/yhst-81132447584496/47699.pdf
Posted on Dec 21, 2010
Directions for use. Do I preheat and how much kernels do I put in?
Yes, you should preheat the kettle some. Each model varies on the amount of kernels. 2,4,6,8,12,14,16,20,32 ounce machines are common. Search your popcorn make and model to find out the popcorn recipe.
Oct 07, 2014 | Kitchen Appliances - Others
Nostalgia Popcorn Maker CCP399 - when the popcorn is popped, unpopped kernels come out with the popped kernels. How can I stop this from happening? Thanks!
You cannot. All poppers of that style will a some "fall out". The better commercial machines have very little as the kettles are deeper, but you cannot eliminate it. The unpopped kernels are not reusable.
Oct 24, 2013 | Nostalgia Electrics CCP399 Vintage...
How much oil, corn and salt do I put in a 2085cl gold medal popcorn machine?
That model is a 6oz popcorn machine.
3/4 cup popcorn kernels (6oz)
slight 1/4 cup oil (1.6oz-a quarter cup is 2 oz.)
1 teaspoon popcorn salt.
Sep 17, 2013 | Gold Medal Kitchen Appliances - Others
May I ask how much popcorn can the Elite Epm 250 Popcorn maker can produce?
The manufacturer rates it as a 2.5 ounce kettle. This means 2.5 ounces of raw kernels each batch.
1 ounce of kernels = 1 quart of popped popcorn.
Roughly a half gallon of popcorn every 3-4 minutes.
May 06, 2013 | Elite Epm250 Popcorn Maker
I purchase this popcorn model number ofp901 i have no instructions it looks like the kpm508 and just need to know how much oil and popcorn
The User Manual for the OFP-901 Old Fashioned Popcorn Maker can be found here:
http://nostalgiaelectrics.com/manuals/ofp-901.pdf
Instructions for use can be found on page.
This model is a HOT AIR popper; oil SHOULD NOT be used in this machine.
Simply fill the kernel cap with with kernels and then pour the kerneles down the hole on the top of the unit. Plug in to power supply. Turn on; kernels should pop 2 tp 2 1/2 minutes.
Make sure you place a large enough bowl under the chute!
Mar 09, 2011 | Nostalgia Electrics KPM-508 Popcorn Maker
Kernels jump up and out of maker while maker is working. At least 50% of kernels are wasted. Thanks for your help.
This won't totally solve the problem, but do the following:
  1. turn on the machine and allow to run for about a minute to allow the machine to get hot.
  2. add 1/2 again as much kernals to the popper
  3. tilt the machine back slightly while popping begins
this should reduce your wasted kernals!
Mar 15, 2010 | Toastess Hot-Air Corn Popper Popcorn Maker
Mar 27, 2009 | Kitchen Appliances - Others
Galaxy popper g12 unpopped kernels
The problem you are having is the thermostat inside the kettle is getting weak these can be ordered from Star Manufacturing or a concessions supply place that does repairs Also Gold Medal Product has a similar thermostat that will work in your kettle pt# 47082 Just a FYI
Jan 13, 2009 | Galaxy G18-AT Popcorn Maker
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Kitchen Appliances - Others Logo
77 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
