I have a 5 gal craftsman wet vac, I'm not sure where the foam sleeve goes.
SOURCE: 177611 wet/dry vac
Either you aren't getting the top on correctly so it will latch, or there maybe a problem with the latches. You should have a one year warranty on this, take it back to Sears and have them look at it.
SOURCE: need replacement manual
Go to Sears.com, click on the parts link, put in your model number, a parts list will come up, if you manual is available, you can click on it to buy it.
SOURCE: Craftsman 20 Gal Wet/Dry Vacuum model number 17762
you did take the filter off before useing it wet didnt you make sure the check ball in the filter housing is down in the cage and that the top is locked down properly
SOURCE: craftsman wet/dry vac
It is supposed to have a round plastic plate and a plastic handle with a nut made in it that tightens against the plate to hold the filter on
SOURCE: where can I fnd the attachments for the craftsman
Sears hardware,if you have one near you. Or go onto the internet
