Error message h04
Error cade h04 on Bosch dishwasher - held down Start button (not on/off button) for 3 seconds or until it showed one of the cycles not the h04 error then select your cycle and turn it on normally - saved me some cash I am sure
Tried everything before I found this super helpful tip. Worked. Thank you
I have a Bosch silent plus 50 dba that's only 2 years old. My grandbaby had a great time punching all the buttons. When she left the indicator light said h: 04. Of course I can't find what I've done with the manual. The start button on the far right says reset under it and 3 seconds. Of course that didn't work. I tried the on-off button and holding it down for 10 seconds and that didn't do it. The last attempt was holding down the on/off button and the start button both for 3 seconds and then when I turned the machine back on the code was clear, but she had it stuck in light wash mode. And of course I wasn't doing a light wash. I reset it a few more times by using the start and reset button at the same time for 3 seconds and finally the code cleared and it went back to regular wash. I'm not going to complain about the confusion because it's my own fault for losing the manual but aside from that this is the best dishwasher I've ever owned. It's so quiet nobody can even tell it's running and it cleans really well.
The “h” errors are the delay feature. h02 = 2Hr delay. h04 = 4Hr delay, etc. Press the delay button repeatedly until it cycles past 24Hr delay to zero hour delay.
The Body Module Control (BMC) on a 2007 Chevy Colorado is typically located in the engine compartment, near the firewall. The exact location may vary depending on the trim level and model of the vehicle.
The BMC, also known as the Body Control Module (BCM), is a computerized device that controls various electronic functions in your vehicle, such as the doors, windows, lighting, and security systems.
It is important to consult the vehicle's service manual for the specific location of the BMC, as it can vary depending on the model and trim level, you can also check with a mechanic or a Chevy dealership for more information.
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
SOURCE: AR-M350 H04-01 ERROR
this is a fuser error H04 01 Heat roller low temperature
check the fuser (fixing unit)
