Cleaned filter, still only warm air blows at high heat setting
SOURCE: Honeywell thermostat....Home cooling/heating system....Chromotherm III
On heat pumps, the normal setting is simply an air conditioner working in reverse. The EMT or AUX heat is a supplemental heating system using electric heating elements instead of the hermetic (compressor) system. As far as why the regular heat does not work it can be one of many things. low freon charge. reversing valve not functioning. The defrost cycle not working. Take your pick. you may want to call a service man to repair it as the electric (EMT) is not as efficient.
SOURCE: Central Electric heat not blowing hot or warm air
Make sure you are in the heat mode. Do you hear the wall thermostat click when you raise and lower the set temp. If not replace thermostst. Clean all filters to start. Does your heat source have a pilot light to start or is the unit located out side. If apilot light make sure itis lit. let's go from there
[email protected]
SOURCE: pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
SOURCE: Bought 44155c hunter thermostat air won't turn on.
If unit worked before you tryed changing t-stat then its possible the t-stat wires are shorting each other out.take t-stat back off cut back wires a good 6 to 10 inches or if you dont have that much wire to play with just cut back as far as you can and make sure there is no bare wire touching each other ,then just to test unit to make sure its working ok twist yell.,red,green together this should bring both units on and should blow cold.if this works up to this point on the new stat read directions closely there might be a jumper wire in the stat that needs connected usually from y1 to w1 you would install a jumper wire .see if this helps if not write back i have 1 other solution.i hope this helps
SOURCE: I have an eden pure xl model 1000xl. it is not
The bulbs/ elements for this xl 1000 are very easy to install. Not always too easy to find in stock though. PAY VERY CLOSE ATTENTION to the way the wires are ATTACHED! They MUST be reconnected in the EXACT way they were removed. BUT, just in case you forgot to look, I have pictures of the terminal blocks. Hope this is a help as there are no other diagrams or pictures that I have found on the net! Good Luck!
