Question about Eddie Bauer 3-In-1 with Latch
Booster seat I am trying to figure out the instructions on how to turn the Eddie Bauer seat into a booster seat. It doesn't seem as simple as taking out the harness. Do I do anything with the base? Does it stay attached? (Unfortunately my son chewed on the instructions when he was yonger...)
Posted by VirginiaF on
  • 7 more comments
  • Anonymous Dec 03, 2007
    Hi, I'm having trouble converting the Alpha Omega Eddie Bauer 3 in 1 (2003) into an ordinary booster seat. Can you tell me where I can find instructions? I've lost mine. My email is [email protected] Thanks, Helen
  • lucyandmeggs Dec 24, 2007
    I can't find my instructions either- I need help with the recline function... I am about to tear my hair out- What is the trick???? Meggs
  • redphilly Jan 03, 2008
    WE are trying to convert our Alpha Omega Eddie Bauer to the final stage. WE lost our manual. Please help.
  • BurgerF1 Jan 05, 2008
    I've also lost the instruction manual on converting the seat to a booster. I'm also unsure what to do with the base. Does it stay on until my son reaches a certain height?
  • shaunapon7 Aug 24, 2008
    I NEED HELP ADJUSTING THE STRAPS
  • Anonymous Aug 24, 2008
    we took our harnest dont know what to do next?
  • mginer Oct 13, 2008
    Same Problem, can take off the base"!!!
  • garettamy Oct 28, 2008
    I am trying to figure out how to make the three in one turn into a high back booster for my daughter....I can't find the manual....
  • Pibbah Jan 10, 2009
    It states that at 40 lbs you convert to booster, but at 34 lbs the straps do not fit for my daughter. She is strapped in so tight it is not comfortable. Can the booster be used prior to 40 lbs safely?
Karen Glover
  • 3 Answers
Converting the seat to a booster: (Alpha Omega Elite Deluxe 2004 version, Eddie Bauer)
After all said and done, the base can probably be left on, it helps to recline the chair when the child is asleep. If you want to leave it out, the manual says the base can be removed for narrow vehicle seats or airline use. Locate the center bar at the bottom of the seat, push the tab at the end of the bar and pull the bar out. The seat can then be separated from the base. The seat has a "kickstand" that can be pulled out to sit the seat upright. Put the bar back in the base so you don't lose it.
To remove the harness, remove the base first. Then from the back of the seat, unfasten the harness from the harness bracket. Store the bracket by looping it behind and around the back spine of the shell. You can unthread the harness from that point and pull it out. From the bottom of the seat, locate the buckle's metal clip. Insert the clip up through the shell and pad, from the front pull the buckle free from the shell. Lock latch plates into buckle for safekeeping.
Once the seat is converted to adult straps don't use the latch system; hook the hooks together to keep it from swinging around, and place the top anchorage strap behind the seat with the anchor hook under the seat.
Posted on Oct 28, 2008
Anonymous
You do remove the base of the car seat by pushing out the metal bar from the base/seat. From here you can remove the harness system and buckle.
Posted on Mar 09, 2008
Angell XP
  • 27 Answers
Most car seats have plastic clips around the edges that will come off. if you work around all the edges you can eventually get it off. The straps can be difficult to remove. Just pay close attention to how they came apart. Take pictures if you have to. They are a paint to put back if you don't.
Hope this helps,
XP
Posted on Nov 14, 2007
  • Angell XP
    Angell XP Nov 14, 2007
    Sorry for the confusion... wrong listing.
    XP
Need an electronic manual for an Eddie Bauer 22-858 Shelton Booster Car Seat. Thanks
Hello
You can call this number 1-800-544-1108 You can also click on this website, it will allow you to search for your model. http://www.eddiebauer.djgusa.com/usa/eng/Instructions
Try the link!
Thank you
May 01, 2010 | Eddie Bauer 22-858 Shelton Booster Car...
The cushions was taken off because it needed to be washed, now they cannot figure how to make sure the straps are right.
The manufacturer's instructions are the final authority - don't trust anyone else giving you instructions! Here are the links to download Dorel/Eddie Bauer carseat instructions:
Canada:
http://www.eddiebauer.djgusa.com/can/eng/instructions
USA:
Mar 16, 2010 | Eddie Bauer Deluxe High Back Booster...
Eddie Bauer Booster Car Seat 22-880 how to take covers off
Canada:
USA:
Mar 13, 2010 | Eddie Bauer Booster Seat
I am trying to take the cover off the eddie bauer 3 in 1 to wash it. How do you get it apart from the buckle/latch that goes between their legs? It seems to be too big to go through that hole without...
Unbolt the seat from the floor of the truck... turn it upsidedown over a table or some such and the you will see the hog rings that hold the cover to the foam and bottom frame...
Jun 14, 2009 | Eddie Bauer Deluxe High Back Booster...
Eddie Bauer booster seat
EUREKAAAAAA!!!!! http://eddiebauer.djgusa.com/instructions/
try there, i found the manual of mine...
May 27, 2008 | Eddie Bauer Baby Gear
Eddie bauer playyard
Dorel Juvenile Group is the company you contact for any thing dealing with eddie bauer
Misplacing product instruction manuals can be such a headache. That’s why a downloadable version of many of our instruction manuals are available right here online. Simply fill out the form below and click Search!
link: http://eddiebauer.djgusa.com/instructions/
call for help: (800) 544-1108
(7 a.m. to 6 p.m. EST Monday through Thursday,
and 7 a.m. to 4:30 p.m. EST on Fridays)
Jan 05, 2008 | Eddie Bauer Booster Seat
Booster
Remove straps and belt across the lap!
Nov 04, 2007 | Eddie Bauer Deluxe High Back Booster...
Relacing straps
try looking on the website
from the picture it looks like the eddie bauer 3 in 1 car seat
http://www.coscojuvenile.com/instructions/
here is the link for the web site, just imput your model or product code and you will be able to download the instruction manual
Oct 29, 2007 | Eddie Bauer 3-In-1 with Latch
Eddie bauer 22-755-MAC
here is the link for the database of instruction manuals. in the manual you will see how to change it to a booster
Sep 16, 2007 | Eddie Bauer 3-In-1 with Latch
Eddie Bauer 3-In-1 with Latch Logo
853 people viewed this question
Top Eddie Bauer Baby Gear Experts
superdad1976
NOEL
NOEL
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
