Question about Bosch PB10-CD Radio/CD Boombox
<!-- from fixya rte -->My power box radio wont play usb and cd card - Bosch PB10-CD Radio/CD Boombox
Posted by Raul perez on
Jvc plays only radio cd and usb not getting sound
have unit check seem like audio out put for cd an usb is bad;;
1helpful
I have a 2003 Camry with 6 CD changer. 6 Cd's are stuck in there and wont play. Error comes up. Took it Toyota and they want to take the radio out. $300 bill. should i just get a new radio?
Yes i would to be honest ,a cd player with sd card and usb ,then a 1gb csd card will hold a lot more than 6 cds ,but make sure you get the right cable as if you wire it in and cut cables you could connect to the wrong feeds like the auto volume adjust or the panel lights ,
Cd player flashes ''error'' when you put a cd in. It waa playing fine. Just stopped playing ejected cd.
try another cd wont play if too scratched or dirty. handle disc by edge, dont touch the surface of disc no matter how lightly you hold it, you will leave contaminants that cloud the surface. if none ever work try them in a house cd player still no joy, then discs aare no good, if they work in home player then car cd died, time for new one. heck who uses cd any more? its a hassle to change them (only 16 songs!), hassle to replace lost daamaged or stolen(borrowed by friends), skip or scratches, get a radio with usb reader/player or SD card reader, can be had for under $60 , an 8gb SD card for $25 (4,000 songs<do you even KNOW the names of that many songs?) PLus, without a cd slot the thieves should leave your radio alone, thinking its just a normal am/fm radio. goto www.dealextreme.com for great deals and FREE SHIPPING.
My car radio just stopped working? cd player works still
if your cd player still works and plays through the speakers, but your radio wont play through the speakers. i would suggest checking the antenna in the back of the stereo. most stereo's wont even play static if the antenna is disconnected. if the antenna is connected behind the stereo go to the passenger side door usually under the glove box is another antenna connection check to see if that one is intact. if that one is it usually means the antenna itself is not tight enough on the body.
1helpful
Bosch Power box radio PB10 radio wont work
This might sound daft but does radio work with a battery in it ?
CD wont play
if it is new you may have left the screw in the back of the radio you have to takje this screw out for the laser to function it should have a plastic box on it
Bosch PB10-CD Radio/CD Boombox Logo
Top Bosch Audio Players & Recorders Experts
ADMIN Canada
ADMIN Canada
shibu tv
Are you a Bosch Audio Player and Recorder Expert? Answer questions, earn points and help others
