Question about Canon PowerShot A620 Digital Camera
Where can I buy a SD 2GB Memory Card
Memery Card
    New Friend:
  • 38 Answers
EBay, Walmart, Target, Best Buy
Posted on Aug 31, 2014
5 Suggested Answers
Anonymous
SOURCE:
leecom72
Lee Hodgson
  • 4806 Answers
SOURCE: Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Posted on Sep 03, 2009
t00nz
CameraR
  • 4738 Answers
SOURCE: Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Posted on Oct 19, 2009
fblock
Fred Block
  • 289 Answers
SOURCE: memory card stuck in powershot sx130 iscamera
To get the card out. push it down and you'll hear a click and then it will pop up. Check the slide switch on the card to see if it's locked which "might" be causing the error.
Posted on Jan 05, 2012
DENNIS RICHARD
  • 118 Answers
SOURCE: Canon IXUS 970 IS will not recognise 2GB SD card although it used to do so
The memory card might have been damaged.If it was a problem with your camera it might not have recognized your 32k sd card.
So buy a new sd card.
Posted on Jun 10, 2012
Memory card
You may use any MMC or SD card, 2GB or smaller. MMC cards are nearly extinct to an SD card will be easier to find. You don't have to worry about the brand or speed, though personally I'd go with the major brands.
Make sure you get an SD card, 2GB or smaller. The S600 will not work with higher-capacity SDHC cards.
Jun 17, 2013 | Samsung Digimax S600 Digital Camera
Jun 10, 2012 | Canon IXUS 970 IS Digital Camera
My pc dont read micro sd scandisk 2gb, I need drivers
buy a cardreader.put the micro sd memory card in the cardreader's slot.connect cardreader to the to the computer and the computer can read your memory card.
May 31, 2011 | SanDisk 2GB microSD Memory Card
Is there a way to get the DC E53 camera to accept a larger SD card than the 512mb that it currently accepts?
The following link describes the maximum SD card size for your camera.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/BenQ/BenQ+DC+E53_Memory_Cards
The following is from their site:
BenQ DC E53 BenQ DC E53 Memory Cards (SD Card) & Accessories
The following digital camera memory cards are compatible with your BenQ DC E53. Every digital camera memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your BenQ DC E53 accepts SD Card cards.The largest SD Card card you can use in your BenQ DC E53 is 2GB
So you can buy up to 2GB SD cards.
Jan 05, 2011 | BenQ DC E53 Digital Camera
Where can I insert my mini sandisk memorycard into my toshiba laptop? I see no slots for it.
If you have no SD slot on your laptop, you will have to buy an external USB SD reader. They typically cost $5-$10, and are readily available online (e.g. http://www.buy.com/prod/micro-sd-sdhc-card-usb-reader-for-1gb-2gb-4gb-8gb/q/sellerid/23962916/loc/101/213271933.html) or in almost any store with a good selection of electronics.
Dec 06, 2010 | SanDisk 2GB microSD Memory Card
Display reads "images recorded in internal memory" but there are none and I can't take more than 4 pictures until the camera says the memory is full. Also the memory card says it is full after 7 pictures,...
hi, the memory card you are using is to small for the camera it has not got enough memory on it you need to get at least a 1gb memory card or 2gb memory this will then allow you to take between 500 and 1000 pictures the 16mb card you have in is not worth using it will only hold a couple of pictures so go to the well known auction site and buy a 2gb memory card of the same type such as sd card or micro sd or mini sd it should tell you on the 16mb card what type it is then just buy the same type but with either 1gb or 2gb or even 4gb of memory this will then let you take 1000s of pictures
the 16mb card is no good in your camera get a bigger card and your problem will be solved
let me know if you have any problems with the new card ok
Aug 15, 2010 | Fuji FinePix A800 Digital Camera
Data transfer for vegas pro 9.0 editing
you need to buy a card reader, plug the sd card in it, then plug the card reader in the usb port of the laptop...no need for special drivers
May 11, 2010 | SanDisk 2GB microSD Memory Card
My Micro SD Card No.- Kingston 2GB micro SD Card
My Kingston Micro sd-c02G is Locked i want unlock password
Jan 04, 2010 | Kingston 2GB Secure Digital Memory Card
Memory
your phone memery is full it will say memery is full
empty the phone memery it will go perfectly
Nov 14, 2009 | Lands Phones
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Jun 01, 2009 | Kodak EasyShare C330 Digital Camera
Canon PowerShot A620 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
