SOURCE: inkjet refills
hi,
as you are using a refilled cartridge, it is causing this problem. the thickness of ink in a hp genuine cartridge and a refilled cartridge varies. and also the refilled cartridge may make your printer faulty. so it is good to try with a new hp genuine ink cartridges.
thanks and regards
agnel
SOURCE: printer error in my hp business inkjet 2800 printer
not sure what error you are facing, but below link might be able to help you on the appropriate actions to take...
http://etech.maiila.com/hp-color-laserjet-2800-all-in-one-printer-series-driver-manual-and-software-download-including-for-vista
good luck
SOURCE: Printer Reset instructions for HP 564 inkjet cartridge.
Dear, this is basically an auto generated message based on system registery keys, if you want to bypass the message, then there are two ways.
1. put another cartridge in the printer and try to print, after than install the previous (original) cateridge, this will doge the printer as a new cateridge, you problem will be removed. but if you don't have another similar cateridge at hand then follow the step 2 given below.
2. Uninstall the driver, unplug the printer, restart the system and reinstall the printer dirver again, your problem will be removed.
Best regards.
SOURCE: Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
SOURCE: reset hp2800 1-800-532-4187 SPAM SPAM SPAM
Hard Reset
Remove the cartridges from the printer then unplug the power cable from
the back of the printer and from the walljack wait for 30 seconds then
replug the power cable to the wall out let and then to the printer.
Power Drain
the back of the printer and from the walljack wait for 30 seconds now
press and hold the power button on the printer and replug the power
cable to the wall out let and then to the printer after the power cable
is connected you can let go off the power button..
