Question about Pioneer CDX-FM687 6-Disc CD Changer
Cant play cds
We cannot play cds in our car stereo system we are getting an error e11 when we try to the model is 6000 cd series any idea what the problem is
Posted by cathsam on
Anonymous
Easy peasy (for me at least).
Disconnect the battery, then...
... reconnect the battery
Just done it to mine - all hunky dory.
The CD 'rebooted' - equivalent to turning a PC off and on again!
Delighted to save the time and expense of visiting a garage!
Posted on Mar 08, 2009
Anonymous
All 6 cds are inside changer and when try to play , an error appears on display.
are you comfortable removing the stereo from the dash board? if it were me, i would remove the stereo then take the cover off of it and try to dislodge any cds which are stuck or jammed
Jul 08, 2011 | Car Audio & Video
When trying to play cds keep getting ''E'' error message. this is in my car cd player. any suggestions
If the message is "error" The CD Lens is bad. Try disconnecting the negative lead from the car battery for about 10 min. But! Make sure your stereo does not have an anti-theft system, because if you disconnect the battery the stereo needs to put a code or will not work again. If after this your stereo still not working you have to take it to any electronics repair shop (the CD lens is bad).
Jan 05, 2010 | Car Audio & Video
I have a JENSEN CD311X car stereo!
IF THIS PROBLEM HAPPENS TO ALL CDS PLAYED, COULD BE THE OPTICALS LENS IS DIRTY, TRY TO CLEAN IT, OR IF ORGINAL CD CAN BE PLAYED THEN THE OPTICAL LENS ARE NOT PROGRAMMED TO READ THE COPIED ONES
Oct 13, 2009 | Car Audio & Video
Fiat Punto Grande Stereo will not play CDs
the lens is not good it can't read the cd
Aug 21, 2009 | Car Audio & Video
Clarion boat stereo- Error 6
well over time the cd reader in side the unit goes and that what is happen to your unit best solution replace the init
Jul 01, 2009 | Clarion DXZ545MP CD Player
CD changer will not play reads "player error" .
Most new car-stereo's don't have an "oldschool" CD-drive, but really a CD-ROM drive; meaning that they won't (properly) read and/or play copy-protected CDs.
Most CD protections are specially designed not to work in CD-ROM drives to prevent copying. As a side-effect most of those protected CDs won't work in car-stereo's.
Try a CD without copy-protection (like an homemade audio CD using burning software on your computer) and see it that works ?
In case that doesn't work either, your car's CD-drive is probably broken ...
Mar 22, 2009 | 2004 GMC Envoy
Monsoon raido Cd Error
just replaced my 2006 Pontiac G6 GT Monsoon 6 CD changer with an identical model pulled from a totaled car.How do I reprogram it so it works on my car.
Dec 14, 2008 | 2006 Pontiac G6
DespLady
It is error message of HiFi when it finds problem in Tape Mechanism. Tape mechanism is stucked and needs to be reset. Open your HiFi and rotate the capstan wheel with finger and then try to power up.
Jul 20, 2008 | Sony MHC-GX450 CD Shelf System
Error
Well. you may have got a cd jammed or stuck in there. it happened to me. but i didnt know the cd fell into the stereo until one day when i closed the cd tray. it got stuck. so i took it apart and there was a cd in there!
Aug 05, 2007 | RCA RS2635 CD Shelf System
Pioneer CDX-FM687 6-Disc CD Changer Logo
314 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
