Cameras Logo
E
Enna Saunders Posted on Aug 31, 2014
How can I focus the screen on my camera? The screen is blurry.
I just received my Polaroid digital camera iS2634 and the screen on my camera is blurry since I took it out the box. Can not take any pictures. Please help. Thanks.
Alan Grothe
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Aug 31, 2014
Alan Grothe
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
600
Points
9
Make sure your lens and any other small sight glass areas on the front of your camera. Some of these lenses are for the auto focus and may not work if dirty.
WHERE CAN I FIND A MANUAL FOR MY IS2634 DIGITAL CAMERA
Did you do a search for it on Google? IS2634 Digital Camera owner's manual. I did and found this:
  1. Customer Reviews Polaroid IS2132-BLACK 16MP 21X Zoom Digital ...
    www.amazon.com/.../product-reviews/B008RFA3BQ - 233k - Cached - Similar pages Read honest and unbiased product reviews from our users. ... The camera comes with a disk that you use to download the 67 page manual and software. Did you get the disk? If not, you may have search for Polaroid's phone number.
Why is my screen blurry and out of focus?
First-things first,
Check to make sure the lens is free of grit! When the lens becomes dirty, the image on your screen will be blusry and out of focus.
Aug 31, 2014 • Cameras
I dropped my Polaroid i735 Digital Camera once and the screen has been blurry...even the pictures turn out blurry. Is there any way to fix the screen?
You dropped it only once? Hmmmm ....
I don't think the problem is with the screen.
It's more like the lens can't focus properly anymore, and there is nothing you can do to fix it.
I'd take it to my local camera repair place, and give them the classic:
"Don't ask me what happened. I lent it to my baby-brother, and he said the camera worked OK."
They just may give you a free estimate.
1helpful
VIEW SCREEN IS SO BLURRY I CAN'T TELL WHAT ITS SHOWING.
Is it the viewfinder (that you hold up to your eye) or the screen that's blurry?
If the viewfinder is blurry, there should be a diopter adjustment to fix it, probably right above the rubber eye cup.
If the screen is blurry, you should take some pictures and video and view them on a computer. I they are sharp on the computer but blurry on the camera screen, there may be a problem with the screen and you may need to take it in for repair.
If the pictures are blurry on the computer as well, the camera may not be focusing properly. If you can't focus manually, or the camera can't focus when auto focus is turned on, you have good light, and aren't too close to your subject, then it may need to be serviced.
Blurry pictures
Good day,
I have heard a lot of complaints about people taking Blurry Photos.
There are a few possibilities for it and a few easy fixes.
The first possibility I would identify is a dirty lens. To fix this simply take a clean microfiber cloth and gently clean the lens until there are no smudges visible.
The other possibility I would identify is that the pictures are out of focus.
This problem can be caused by a dirty lens or because the object or person was not focused on. To ensure focus on your photos, line up your shot and wait for the camera to focus by pressing the shutter button half way down. When focused press the shutter button in all the way and hold the camera still until the photo appears on the screen. By doing this you will eliminate any motion that might mess up your shot.
Please let me know if these tips work for you!
Regards
Why does my Polaroid camera a930 take blurry pictures?
The lens is probably out of focus. Try fixing it or just getting a new camera.
My pictures are very blurry.. We have reset to the default settings but the pictures are still coming out blurry... This was not a problem before as we have had clear pictures. What do you think the...
The auto-focus might be bad. Set to manual focus and see if that works. If not, then the focus motor is slipping or the motor itself is bad and cannot focus the lens properly.
6helpful
2answers
I have an I835 with blurred vision in the lcd screen. no matter how close or far the subject is its blurred
Remove the memory card. Reset the camera to default settings (Reset All in the Setup Menu). Don't worry, it won't erase any photos. Try taking a picture in a well-lit area at a moderate distance, with the camera resting on something to keep it still. If it still looks blurry, transfer to the computer and view it there. If that's not blurry, it's the LCD display. If it is, then it's the internal focusing system. Locate your receipt and call Polaroid for service.
Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
